Topic: Unable to create a file on SD card using arduino UNO. (Read 955 times) previous topic - next topic
Vai777
I want to merge two different codes that is inserted below. When I merge them, the value obtained by analog input shows up on the serial monitor but does not get stored onto a file in the SD card. It would be great if you guys could help me out.
1) Code to create a new file on SD card
Code: [Select]
#include<SD.h>
#include<SPI.h>
File myFile;
int pinCS = 4;
Serial.begin(19200);
pinMode(pinCS, OUTPUT);
if(SD.begin())
Serial.println("The SD card is ready");
Serial.println("The card initialization failed");
return;
int sensorValue = analogRead(A0);
Serial.println(sensorValue);
myFile = SD.open("example.txt", FILE_WRITE);
delay(100);
if(myFile)
myFile.println(sensorValue);
myFile.close();
Serial.println("Error opening example.txt");
2) Code I want to merge with the above one.
Code: [Select]
//this code will enable all three Arduino timer interrupts.
//timer will interrupt at 1Hz
Serial.flush();
cli();
TCCR1A = 0;
TCCR1B = 0;
TCNT1 = 0;
OCR1A = 61;
TCCR1B |= (1 << WGM12);
TCCR1B |= (1 << CS12) | (1 << CS10);
TIMSK1 |= (1 << OCIE1A);
sei();
ISR(TIMER1_COMPA_vect)
Serial.println(analogRead(A0));
void loop
