Topic: Mkr1010 disconnects and reconnects normally until it doesn't (Read 387 times) previous topic - next topic
Oretoh
I honestly have no idea what happens. The thing is, he does reconnect from time to time, but there are times where it just disconnects and never reconnects again and I can't replicate the damn thing because while I run it with Serial open and turn off and on my wifis he always reconnects as it should.
Code: [Select]
#include <ArduinoHttpClient.h>
#include <WiFiNINA.h>
#include <EmonLib.h>
EnergyMonitor emon1;
EnergyMonitor emon2;
EnergyMonitor emon3;
int INTERVAL = 60;
int last_code = 0;
char ssid[] = "MySSID";
char pass[] = "MyPW";
String ID = "Garden_Pump_Sensor";
int sequence = 0;
double kWh = 0.0;
char serverAddress[] = "192.168.1.108";  // server address
int port = 5005;
WiFiClient wifi;
HttpClient client = HttpClient(wifi, serverAddress, port);
int status = WL_IDLE_STATUS;
  analogReadResolution(9);
  emon1.current(0, 100);
  emon2.current(5, 100);
  emon3.current(6, 100);
  Connecting();
void Connecting() {
  int tries = 4;
  while ( (WiFi.status() != WL_CONNECTED && tries > 0) || last_code != 200) {
    Serial.print("Status #1: ");
    Serial.println(WiFi.status());
    WiFi.begin(ssid, pass);
    Serial.print("Status #2: ");
    tries--;
    last_code = 200;
  Serial.print("SSID: ");
  Serial.println(WiFi.SSID());
  IPAddress ip = WiFi.localIP();
  Serial.print("IP Address: ");
  Serial.println(ip);
void reconnecting() {
  if  (WiFi.status() != 3  || (WiFi.RSSI() <= -90) || (WiFi.RSSI() == 0) || last_code != 200) {
    WiFi.end();
    Connecting();
  unsigned long delayTime = INTERVAL * 1000;
  unsigned long time_start = millis();
  DataMonitorAndSend();
  unsigned long time_final = millis() - time_start;
  unsigned long delay_value = delayTime - time_final;
  Serial.println(delay_value);
  if (delay_value < 1  || delay_value > delayTime) {
    return;
    delay(delay_value);
void DataMonitorAndSend() {
  reconnecting();
  Serial.println("making POST request");
  String contentType = "application/json";
  kWh = kWh + getKWH();
  String postData = "{\"ID\": \""+ID+"\",\"seq\": " + String(sequence) + ",\"kWh\": " + String(kWh, 6) + "}";
  Serial.print("data: ");
  Serial.println(postData);
  client.setHttpResponseTimeout(5 * 1000);
  client.post("/receivedata/", contentType, postData);
  // read the status code and body of the response
  int statusCode = client.responseStatusCode();
  String response = client.responseBody();
  Serial.print("Status code: ");
  Serial.println(statusCode);
  if (statusCode == 200) {
    kWh = 0;
    sequence++;
  last_code = statusCode;
  Serial.print("Response: ");
  Serial.println(response);
double getKWH() {
  int LOOPS = 15;
  double kWh_Total = 0.0;
  unsigned long delayTime_kwh = 2 * 1000;
  for (int i = 0; i < LOOPS; i++) {
    unsigned long time_start_kwh = millis();
    double Irms1 = emon1.calcIrms(600);
    if (Irms1 < 0.3) Irms1 = 0;
    double Watt1 = (Irms1 * 230) / 1000;
    double Irms2 = emon2.calcIrms(600);
    if (Irms2 < 0.3) Irms2 = 0;
    double Watt2 = (Irms2 * 230) / 1000;
    double Irms3 = emon3.calcIrms(600);
    if (Irms3 < 0.3) Irms3 = 0;
    double Watt3 = (Irms3 * 230) / 1000;
    kWh_Total = kWh_Total + ((Watt1 + Watt2 + Watt3) / 60);
    unsigned long time_final_kwh = millis() - time_start_kwh;
    unsigned long delay_value_kwh = delayTime_kwh - time_final_kwh;
    if (delay_value_kwh < 0  || delay_value_kwh > delayTime_kwh) {
      delay(0);
      delay(delay_value_kwh);
  return kWh_Total / LOOPS;
Feel free to ignore the getkWH(), it's code related to power consumption. Also the firmware is up to date and the server is running in a static IP.
Sneha7
I have then same problem with the MKR1010. It keeps disconnecting and sometimes it won't reconnect. I lost a lot of data because of this. Can anyone help how to troubleshoot this problem?
