Topic: [SOLVED] Powering Arduino MKR 1010 through Vin. (Read 510 times) previous topic - next topic
martinnp
Jul 04, 2019, 09:48 am Last Edit: Jul 18, 2019, 07:11 pm by martinnp
Hello,
I'm trying to feed my Arduino MKR 1010 through the Vin pin, without any battery conected. The ON led lights up normally, but the WiFi module doesn't work (it only works when it's conected to the USB). Do I need to conect a battery or my Arduino is just damaged? I am supplying 5V with a lab powe supply.
Hope you can help me,
Martin.
gbafamily
You program may require the USB port. Look for code like this "while (!Serial)". Comment out the code.
martinnp
Hello,
thanks for the answer. The problem was that my power supply couldn't provide enough current.
Sneha7
#3
Aug 09, 2019, 10:51 pm Last Edit: Aug 12, 2019, 05:44 pm by Sneha7
@gpafamily Thanks. I was not able to figure why mkr1010 WiFi was only working when I connect it to computer or laptop and it wasn't working when I connect it to external power source until I saw your post.
