Topic: Problem uploading to board (Read 192 times) previous topic - next topic
Boba_the_great
Arduino: 1.8.9 (Windows Store 1.8.21.0) (Windows 10), Board: "Arduino/Genuino Uno"
Sketch uses 3582 bytes (11%) of program storage space. Maximum is 32256 bytes.
Global variables use 216 bytes (10%) of dynamic memory, leaving 1832 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x2e
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x2e
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x2e
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x2e
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x2e
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x2e
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x2e
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x2e
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x2e
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x2e
Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
option enabled in File -> Preferences.
what do I do to fix this????
Geniussmo
The story makes me very confused. You make it clear
คาสิโนออนไลน์
sterretje
#2
Jul 14, 2019, 06:11 am Last Edit: Jul 14, 2019, 06:12 am by sterretje
Did this suddenly start or is this the first time that you're using the IDE? Are you're using a clone or an original Arduino?
Did you select the correct serial port in the IDE? Note that COM1 is usually not the Arduino. Check in device manager which port shows up under ports when connecting the Uno; that's the port to use in the IDE. Make sure that no new yellow triangles show when connecting the board.
The bootloader on the board might be missing; this is sometimes the case with clones. You can check this by observing the board's behaviour at startup. After powering it up or connecting to the computer, the LED on pin 13 should flash a few times quickly before running the currently loaded sketch (new boards usually come with the blink sketch preloaded and in that case will flash the LED with one second on, one second off).
The Windows Store version can cause some strange problems. I suggest that you uninstall and use the normal IDE.
If you understand an example, use it.
If you don't understand an example, don't use it.
Electronics engineer by trade, software engineer by profession. Trying to get back into electronics after 15 years absence.
