Topic: SineFade - Extremely simple LED fade using a PWM pin and Sine function.  (Read 133 times) previous topic - next topic
stievenart
Jul 10, 2019, 09:43 pm Last Edit: Jul 26, 2019, 04:32 am by stievenart Reason: More functionality
I have searched for an easy example for a fade program using PWM and the Sine function. After realizing there wasn't a simple one, I did what all of us do... and "make" one. I call this one SineFade and it creates an extremely smooth breathing effect. More so, than other fade programs I have tried. The current fade programs just count in a linear fashion, up and down. This example uses the Sine function and one PWM pin.
Fritzing diagram:
Schematic:
Note: I have added the serial output that works nicely with the "Serial Monitor" in the Arduino IDE.
See this code at work: https://www.youtube.com/watch?v=VGPpQy784j0
Code: [Select]
  SignFade
  This is a very simple example showing how to smoothly fade a LED using the Sine function and a PWM
  pin. I have seen many complex and confusing examples. And, I felt that a simple version was needed.
  This code was written by Greg Stievenart with no claim to the information provided in this code.
  Please feel free to copy, modify and share. Freely published July 8, 2019
  PWM is broken into a resolution of 255 units. The units in this example are broken down into an
  imaginary circle with a radius of 255 divided by 2. This number is multiplied by the Sine of
  the wave.
  EXAMPLE:
   255/2       **                      **                      **                        **
       0 * ---------- * -------- * ---------- * -------- * ---------- * ---------- * ---------- *
  -255/2                   **                      **                       **
  More information about the Sine fuction: https://en.wikipedia.org/wiki/Sine
  This project is posted at: https://forum.arduino.cc/index.php?topic=625662.0
  Project inspired by post at: https://forum.arduino.cc/index.php?topic=27475.0
int led = 9;                                              // The PWM pin the for the LED.
int brightness = 0;                                       // LED brightness.
  pinMode(led, OUTPUT);                                   // Pinout set to pin 9.
  Serial.begin(9600);                                     // Initiates serial communication
void loop() {                                             // Main loop
  for (int i = 0; i < 360; i++) {                         // 360 degrees of an imaginary circle.
    float angle = radians(i);                             // Converts degrees to radians.
    brightness = (255 / 2) + (255 / 2) * sin(angle);      // Generates points on a sign wave.
    analogWrite(led, brightness);                         // Sends sine wave information to pin 9.
    Serial.println(brightness);                           // "Serial Monitor" or "Serial Plotter" information.
    delay(15);                                            // Delay between each point of sine wave.
lastchancename
And the code that @stievenart missed posting
Code: [Select]
  SignFade
  the wave.
  EXAMPLE:
   255/2       **                      **                      **                        **
  -255/2                   **                      **                       **
void setup(){
void loop(){                                              // Main loop
  for (int i = 0; i < 360; i++){                          // 360 degrees of an imaginary circle.
    analogWrite(led,brightness);                          // Sends sine wave information to pin 9.
Experienced responders have a nose for laziness, (they were beginners once)... Sure, there are trolls, chest-beaters, and pretenders - but the help you'll get here is about as good as it gets - if you try to help youself!.
