Topic: Stepper Motor libraries that aren't so choppy (Read 241 times) previous topic - next topic
clamthief
I've run the default library for Arduino using a ULN2003 driver board and a 28BYJ-48 stepper and the motor vibrates a lot and is very choppy. I used a library called AccelStepper at first and the movements were much smoother, but the documentation for the library doesn't exist this makes it a little difficult to use. This is the code I'm using the example one stepper revolution code.
Robin2
The Accelstepper documentation is not perfect, but it is one of the best documented Arduino libraries.
And you have not posted any code.
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
jremington
Avoid chop by using a bipolar stepper with a decent microstepping driver, with the current limit set properly.
clamthief
Thanks, Robin2 I was going through the zip file links and the site it brought me to was filled with links that had no website on the other end of them.
