Topic: Sound sensor & LED delay in automation project (Read 43 times) previous topic - next topic
ajmemeni
Hi everyone, I hope I can resolve these 2 things:
I have arduino project - House automation
I need to adjust few things:
 1. milis instead delay
- for example LED via ldr and PIR motion sensor - because when I use delay led is ON for few seconds, but in the meantime I cant use my other sensors ( I cant use RFID card reader when LED is on)
I tried few things, but nothing worked so far..
Code: [Select]
void readLIGHT()
 String string1 = "Lighting percentage: ";
  String string2 = string1 + light;
  int value_pir = digitalRead(PIR);
  String string3 = "Motion detector: ";
  String string4 = string3 + value_pir;
  light = map(analogRead(ldrPin) , 0 , 1024 , 1 , 100);
  Serial.println(string2);
  Serial.println(string4);
  if ((light < 50) && ( value_pir == HIGH) )       //This is percentage of light intensity. can be changed between 0 - 100
    digitalWrite(lightingOutput, HIGH);
    Serial.println("Lighting ON");
    delay(8000);
    digitalWrite(lightingOutput, LOW);
    Serial.println("Lighting OFF");
2. I have working code for sound sensor - When I clap hands turn on/off LED,
but when I put code in my automation project with others - it doesnt work, its somehow blocked by other sensors/code?
This is sound sensor clap code:
Code: [Select]
int LED=5;
int soundSensor=A1;
boolean LEDStatus=false;
  pinMode(soundSensor,INPUT);
  pinMode(LED,OUTPUT);
  int SensorData=analogRead(soundSensor);
  if(SensorData>600){
    if(LEDStatus==false){
        LEDStatus=true;
        digitalWrite(LED,HIGH);
    else{
        LEDStatus=false;
        digitalWrite(LED,LOW);
    delay(50);
Whole code:
Code: [Select]
#include <Servo.h>
#include "DHT.h"
#include <SPI.h>
#include <MFRC522.h>
#include <Wire.h>
#define SERVO_PIN 8
#define SS_PIN 10
#define RST_PIN 9
#define lightingOutput A2
#define ldrPin A0
#define PIR 7
#define ledGrn 6
#define heatingOutput A3
#define coolingOutput A4
#define DHTPIN 2
#define DHTTYPE DHT11
MFRC522 mfrc522(SS_PIN, RST_PIN); // Create instance of our reader
Servo myservo; // Create instance of our motor /// create servo object to control a servo
DHT dht(DHTPIN, DHTTYPE);     //// Initialize DHT sensor for normal 16mhz Arduino
int pos;
int light;
float h, t;
int soundSensor=A1;
int LED=5;
const int buzzer = 4;
  dht.begin();
  SPI.begin();
  mfrc522.PCD_Init();
  myservo.attach(SERVO_PIN);
  myservo.write(0);
  pinMode(heatingOutput, OUTPUT);
  pinMode(coolingOutput, OUTPUT);
  pinMode(ledGrn, OUTPUT);
  pinMode(lightingOutput, OUTPUT);
  Serial.println("\nHOME AUTOMATION\n");
  readSOUND();
  readRFID();
  readDHT();
  readLIGHT();
void readRFID()
  //Look for new cards
  if ( ! mfrc522.PICC_IsNewCardPresent() ) {
    return;
  if ( ! mfrc522.PICC_ReadCardSerial() ) {
    return;
  // If a card is detected, execute the following:
  Serial.println("Time to open");
  // Print the card's ID
  String content = "";
  byte letter;
  for ( byte i = 0; i < mfrc522.uid.size; i++ ) {
    content.concat(String(mfrc522.uid.uidByte[i], HEX));
    if ( i < mfrc522.uid.size - 1 ) content += "-";
  content.toUpperCase();
  Serial.println("UID tag :'" + content + "'");
  if (content == "C1-E5-86-25") {
    Serial.println("Authorized access");
    digitalWrite(ledGrn, HIGH);
    for (pos = 0; pos <= 90; pos += 1) {
      myservo.write(pos);
      delay(25);
    for (pos = 90; pos >= 0; pos -= 1) {
      myservo.write(pos);
      delay(70);
      digitalWrite(ledGrn, LOW);
  else {
    Serial.println("Access Denied");
      tone(buzzer, 1000, 6000);
void readDHT()
  h = dht.readHumidity();
  t = dht.readTemperature();
  Serial.print("Humidity: ");
  Serial.print(h);
  Serial.print(" %\t");
  Serial.print("Temperature: ");
  Serial.print(t);
  Serial.print(" *C ");
  if (t < 18) //if temperature is less than 25 celcius
    digitalWrite(heatingOutput, HIGH);
    Serial.print("Heating activated\n");
    digitalWrite(heatingOutput, LOW);
  if (t > 22) //if temperature is more than 30 celcius
    digitalWrite(coolingOutput, HIGH);
    Serial.print("Cooling activated\n");
    digitalWrite(coolingOutput, LOW);
void readLIGHT()
    delay(8000);
void readSOUND()
  if(SensorData>600){
        LEDStatus=true;
    else{
        LEDStatus=false;
    delay(50);
