Topic: MKR1010 and DS3231 Real Time Clock (Read 366 times) previous topic - next topic
ianhindle
Quite new to programming so I guess this is easy, but I need help.
I've been developing a project on a UNO device which includes a DS3231 RTC and a LCD module, both connected via the I2C bus.
Things are working well, but the final project is planned to work from a MKR1010.
I've attempted to compile the sketch for the MKR1010 and received errors which I've attributed to the DS3231.H header file.
The header file info says it's compatible with the MKR1010. What I've noticed is if I press the "include" button in the IDE (in the library section, next to the DS3231 library) it only added the following lines to the sketch:
// DS3231 - Version: 1.0.2
#include <Wire.h>
To me this is implying the DS3231 library is incorporated into the Wire.h library.
I'm lost, was making so much good progress with my project, using the square wave output of the DS2321 to hardware interrupt the Arduino, every 0.5s.
Below is an extract of a few relevant lines of code I was using when connected to an UNO.
#include <Arduino.h>
#include <DS3231.h>
#include <Wire.h>
#include <math.h>
DS3231 Clock;
iYear     = Clock.getYear();
If anyone can help I'd be most grateful.
Regards
Ian
pert
  • When you encounter an error, you'll see a button  that looks like two pieces of paper at the top right corner of the black console pane below the Arduino Web Editor's sketch pane. Click that button.
  • In a forum reply here, click on the reply field.
  • Click the </> button on the forum toolbar. This will add the forum's code tags markup to your reply.
  • Press "Ctrl + V". This will paste the error between the code tags.
  • Move the cursor outside of the code tags before you add any additional text to your reply.
  • Click the "Post" button./li]
If the text exceeds the forum's 9000 character limit, save it to a .txt file and post it as an attachment. If you click the "Reply" button here, you will see an "Attachments and other settings" link.
#include <Wire.h>
No. It means the author of the library didn't bother to read the documentation to learn how to use the includes field in library.properties:
https://github.com/arduino/Arduino/wiki/Arduino-IDE-1.5:-Library-specification#libraryproperties-file-format
The DS3231 library is NOT incorporated into the Wire.h library. You need to add this line to your sketch if you want to use the DS3231 library:
Code: [Select]
#include <DS3231.h>
I submitted a pull request to the DS3231 to fix that bug:
https://github.com/NorthernWidget/DS3231/pull/15
ianhindle
Have followed your instructions. I should have mentioned I'm using the online IDE from a Chromebook.
Thanks for your help
Ian
Code: [Select]
/home/builder/opt/arduino-builder/arduino-builder -compile -core-api-version 10611 -hardware /home/builder/opt/arduino-builder/hardware -hardware /home/builder/.arduino15/packages -tools /home/builder/opt/arduino-builder/tools -tools /home/builder/.arduino15/packages -built-in-libraries /home/builder/opt/libraries/latest -logger humantags -fqbn arduino:samd:mkrwifi1010 -build-cache /tmp -build-path /tmp/313909984/build -verbose -prefs runtime.tools.CMSIS.path=/home/builder/.arduino15/packages/arduino/tools/CMSIS/4.5.0 -prefs runtime.tools.arc-elf32.path=/home/builder/.arduino15/packages/Intel/tools/arc-elf32/1.6.9+1.0.1 -prefs runtime.tools.openocd.path=/home/builder/.arduino15/packages/arduino/tools/openocd/0.10.0-arduino7 -prefs runtime.tools.bossac.path=/home/builder/.arduino15/packages/arduino/tools/bossac/1.7.0-arduino3 -prefs runtime.tools.x86-linux-gcc.path=/home/builder/.arduino15/packages/arduino/tools/x86-linux-gcc/7.2.0 -prefs runtime.tools.arduinoOTA.path=/home/builder/.arduino15/packages/arduino/tools/arduinoOTA/1.2.1 -prefs runtime.tools.arduino101load.path=/home/builder/.arduino15/packages/Intel/tools/arduino101load/2.0.1 -prefs runtime.tools.i586-poky-linux-uclibc.path=/home/builder/.arduino15/packages/Intel/tools/i586-poky-linux-uclibc/1.6.2+1.0 -prefs runtime.tools.avr-gcc.path=/home/builder/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5 -prefs runtime.tools.avrdude.path=/home/builder/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino8 -prefs runtime.tools.dfu-util.path=/home/builder/.arduino15/packages/arduino/tools/dfu-util/0.9.0-arduino1 -prefs runtime.tools.CMSIS-Atmel.path=/home/builder/.arduino15/packages/arduino/tools/CMSIS-Atmel/1.2.0 -prefs runtime.tools.sketchUploader.path=/home/builder/.arduino15/packages/Intel/tools/sketchUploader/1.6.2+1.0 -prefs runtime.tools.core2-32-poky-linux.path=/home/builder/.arduino15/packages/Intel/tools/core2-32-poky-linux/1.6.2+1.0 -prefs runtime.tools.linuxuploader.path=/home/builder/.arduino15/packages/arduino/tools/linuxuploader/1.5.1 -prefs runtime.tools.nrf5x-cl-tools.path=/home/builder/.arduino15/packages/arduino/tools/nrf5x-cl-tools/9.3.1 -prefs runtime.tools.arm-none-eabi-gcc.path=/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4 -prefs runtime.tools.flashpack.path=/home/builder/.arduino15/packages/Intel/tools/flashpack/2.0.0 -prefs runtime.tools.arm-linux-gcc.path=/home/builder/.arduino15/packages/arduino/tools/arm-linux-gcc/4.9.3 -libraries /tmp/313909984/custom -libraries /tmp/313909984/pinned /tmp/313909984/SCADA_Main_003_1010
WARNING: library liquidcrystal_i2c_1_1_2 claims to run on (avr) architecture(s) and may be incompatible with your current board which runs on (samd) architecture(s).
Multiple libraries were found for "DS3231.h"
Used: /tmp/313909984/pinned/ds3231_1_0_2
Not used: /home/builder/opt/libraries/latest/ds3231_1_0_2
Using library Wire at version 1.0 in folder: /home/builder/.arduino15/packages/arduino/hardware/samd/1.8.1/libraries/Wire
Using library liquidcrystal_i2c_1_1_2 at version 1.1.2 in folder: /home/builder/opt/libraries/latest/liquidcrystal_i2c_1_1_2
In file included from /home/builder/.arduino15/packages/arduino/tools/CMSIS-Atmel/1.2.0/CMSIS/Device/ATMEL/samd21/include/samd21.h:69:0,
from /home/builder/.arduino15/packages/arduino/tools/CMSIS-Atmel/1.2.0/CMSIS/Device/ATMEL/samd.h:105,
from /home/builder/.arduino15/packages/arduino/tools/CMSIS-Atmel/1.2.0/CMSIS/Device/ATMEL/sam.h:540,
from /home/builder/.arduino15/packages/arduino/hardware/samd/1.8.1/cores/arduino/Arduino.h:48,
from /tmp/313909984/SCADA_Main_003_1010/SCADA_Main_003_1010.ino:47:
/home/builder/.arduino15/packages/arduino/tools/CMSIS-Atmel/1.2.0/CMSIS/Device/ATMEL/samd21/include/samd21g18a.h:474:27: error: expected ',' or '...' before '(' token
#define PM ((Pm *)0x40000400UL) /**< \brief (PM) APB Base Address */
/tmp/313909984/pinned/ds3231_1_0_2/DS3231.h:71:33: note: in expansion of macro 'PM'
byte getHour(bool& h12, bool& PM);
exit status 1
pert
Code: [Select]
The problem is there is a macro named PM defined in the SAMD toolchain that is having a collision with the completely unrelated parameter name used in the DS3231 library's getHour function. Luckily, someone already fixed this problem in the DS3231 library:
https://github.com/NorthernWidget/DS3231/commit/17e73b1ddc96c21562bd294972d9c0407112cbf8
Although that fix was included in the 1.0.3 release of the DS3231 library, unfortunately the library author didn't do the release correctly so the 1.0.3 version of the library is not available via the default installation in the online IDE. I submitted a bug report about this:
https://github.com/NorthernWidget/DS3231/issues/16
The solution is to import the 1.0.3 release of the library into the online IDE yourself. I don't have any experience with the Arduino Create app for ChromeOS, so the below instructions  are for using the online IDE via the browser and might need to be modified a little for the app, but I think they will still apply fairly well:
  • Download the 1.0.3 release of the DS3231 library: https://github.com/NorthernWidget/DS3231/archive/v1.0.3.zip
  • In the online IDE, click the "Libraries" tab on the left side of the screen.
  • Click the upward pointing arrow button (Import).
  • If you get a message about importing your sketchbook, click the "Import" button.
  • Select the downloaded file.
  • Click the "Open" button.
  • Wait until you get a confirmation that the library has finished importing.
After that, the error you got should be fixed.
ianhindle
Absolutely perfect.
Followed your instructions, and it all worked first time.
I can't thank you enough and also learned so much with fault finding with this issue.
Thanks so much again.
Ian
pert
You're welcome. I'm glad to hear it's working now. Enjoy!
Per
