since this is my first post just want to say kudos to the community.
So, I am getting a really strange battery behaviour in my current project.
I am trying to build a project that will send me data online for a few days so I've decided to use the arduino and the sim800. Since the arduino would need to work on 5v (because of some sensors) I also put the step-up boost module before it. The sim800 is connected directly to the battery. There is also the power-bank-ish controller to recharge the battery when it gets empty.
You can see the whole setup on the picture, it's rather simple. The batteries are Li-Ion connected in parallel. 6 of them.
Now, the behaviour I'm was getting, which rather scared me was after usage the battery started increasing the voltage (at the begining was 4.1 but rose to 4.3) and when I checked the resistance of the battery pack it basically said it short circuited itself. So the resistance between B+ and B- were 0.
I immediately disconnected the batteries and decided to check with you about what is happening.
My setup seems simple enough, and while i think it can be improved with a charge-discharge protection i still don't understand what happened.
I would appreciate any help about this, what happened, was it dangerous and how to save against it next time.
Also: the batteries were all around 4.1V . The setup is exactly as on the picture, cables are good quality.
