I'm not a battery expert, but I'd "be careful" about putting LiPo batteries in parallel. And, you probably can't get "optimum" charging in parallel.
Battery Resistance:
An "ideal battery" has zero resistance. Real batteries have a (low) internal resistance, but of course it's not a "resistor" and it may not be linear and it may change with the state of charge, etc.
The internal resistance limits the current, it makes the voltage drop when you draw "excess current" (or when you short the battery), and it's the internal resistance that causes a battery to warm-up (when you draw lots of current from it or when it's charged.)
You measure the internal resistance by measuring how much the voltage drops with a known load resistance. You've got a voltage divider and if the voltage drops in half the internal resistance is equal to the load resistance. (But, I wouldn't recommend loading a LiPo battery to the point where the voltage drops in half... You might kill it or start it on fire!)
I've seen cheap LED flashlights that have the LEDs wired directly to the battery (through a switch of course) with only the battery's internal resistance used for current limiting. (The ones I've seen use regular non-rechargeable alkaline batteries.)
