Topic: Need to help with circuit adapts to 5-48V drive DC motor design (Read 855 times) previous topic - next topic
kmimax
Need to design a circuit that uses Arduino to control a 5-48V DC motor. Is the circuit shown feasible?
Paul__B
Sorry, that circuit is complete nonsense.  Try again.
(The motor should be between the drain of the FET and the supply, and there should be a reverse protection diode across it.  What do you imagine the Zener and Schottky diodes and Q1 do?)
raschemmel
Quote
My thoughts exactly. I don't see how that fet could control the motor. It's not in the same current loop as the motor so all it can do is divert current  , which accomplishes nothing because it doesn't affect motor current.
Quote
A bit presumptuous of you to assume he knows what a Schottky diode is based on the fact he posted that
schematic , don't you think ?
@OP,
Here's a couple of examples of how it's done (high side switching with a P-channel mosfet and low-side switching with an N-channel mosfet so if you only have one or the other you can still make it work.
Driving motor with mosfet
FYI, the mosfets have to be rated for the full motor current.
I like this animation...
Arduino UNOs, Pro-Minis, ATMega328, ATtiny85, LCDs, MCP4162, keypads,<br />DS18B20s,74c922,nRF24L01, RS232, SD card, RC fixed wing, quadcopter
kmimax
Thanks for everybody, I am sorry, the circuit is wrong, now change....
raschemmel
kmimax
Have you tried driving it with a PWM pin ?
Is there a problem?Please forgive me, I am a beginner in circuit design. I hope to use PWM to drive. I have tried many circuits and failed because I need to drive high voltage and  current.So far there is no one suitable for 5~48V circuit.
raschemmel
Have you built that circuit yet ?
Paul__B
Have built that circuit yet ?
Subtle comment that.  :smiley-lol:  :smiley-lol:
Clearly that circuit is but a modest improvement.  :smiley-roll:
May I ask from where you are getting these apparently random circuits?  :smiley-eek:
raschemmel
Correction:
"Have you built that circuit yet ?"
(I'm not going to tell him all he needs is the
mosfet and flyback diode.
I'll let someone else do that...
kmimax
raschemmel
HellasT
Correction:
I was also wondering why not use only the mosfet and diode and maybe a resistor from gate to ground just to be on the safe side. Specially if you use a logic gate mosfet like the IRL540 yes ?
Paul__B
Tried such a circuit
And that circuit looks correct, except that it will only function (reliably) with a minimum supply voltage of 15 V.
If you want it to operate on less than that, you do need different components.
raschemmel
I would use one of these because it is logic level and N-channel.
kmimax
If it is 5~48V, just choose a high voltage MOSFET?
