Hello,
I think I have a big problem with the SPI communication :
I am currently trying to make a SPI communication between an "arduino" (Teensy 3.6), and a demo board (LPC5411X, based on NXP MCU LPC54114). The Teensy is the master, and the board is the slave.
Data that I receive and that I sent are wrong or shifted (84 instead of 44, 148 instead of 171 ...).
I think the problem is coming from Arduino :
- LPC Slave + Teensy Master : Not OK
- LPC Slave (same code) + LPC Master (another same board, same data) : OK
- Teensy Master MISO to MOSI (same code) : OK
- LPC Slave (same code) + Teensy Master Bit banging : OK
- LPC Slave (same code) + Arduino Uno Master (same code) : Not OK
- LPC Slave (same code) + Arduino Uno Master Bit banging : OK
Thus, I think the problem is coming from the code/Arduino but I dont know where and why.
I check with a scope, looks like everything is good (I dont have a signal analyzer), pin connection are ok, otherwise I receive only 0 or 255.
- SCK 13
- SS 10
- MOSI 11
- MISO 12
In the example, I sent 2 numbers with 5s delay, and if the slave receives the good number (171 and 8 ), it turn on and off a LED with the 5s delay (and sent back 44 and 171 ), but it is not happening (rarely it happens for some reasons ... ).
I tried to slow down the communication (9600Hz) : Not OK (NXP data sheet says up to 13MHz in slave mode, LPC Slave (same code) + LPC Master is working at 500kHZ, Teensy running at 180MHz)
SPI Mode 0 = CPOL 0 /CPHA 0, same settings on the slave.
Master test code :
#include <SPI.h>
Serial.begin (115200);
SPI.begin();
pinMode(SS, OUTPUT);
digitalWrite(SS, HIGH);
SPI.beginTransaction(SPISettings(1000000, MSBFIRST, SPI_MODE0));
unsigned char x;
delay(5000);
digitalWrite(SS, LOW);
x = SPI.transfer(171); //171=0xAB
Serial.print(x);
delay(5000);
x = SPI.transfer(8); //
Serial.print(x);
while (1) {}
Bit banging test code :
#include <SPI.h>
#define SSL_PIN 10
#define MISO_PIN 12
#define MOSI_PIN 11
#define SCK_PIN 13
pinMode(MOSI_PIN, OUTPUT);
pinMode(MISO_PIN, INPUT);
pinMode(SCK_PIN, OUTPUT);
pinMode(SSL_PIN, OUTPUT);
digitalWrite(MOSI_PIN, LOW);
digitalWrite(SCK_PIN, LOW);
digitalWrite(SSL_PIN, HIGH);
unsigned char rx = 0;
unsigned char tx = 171;
delay(5000);
delay(100);
digitalWrite(SSL_PIN, LOW);
for( int i =0; i<8; i++){
digitalWrite(MOSI_PIN, (tx)&(1<<(7-i)));
digitalWrite(SCK_PIN, HIGH);
delay(1);
rx = rx + (digitalRead(MISO_PIN)<<(7-i));
delay(100);
Serial.print(rx);
rx = 0;
tx = 8;
delay(5000);
delay(1);
delay(100);
Serial.print(rx);
while(1){}
Slave test code :
#include <stdio.h>
#include "board.h"
#include "peripherals.h"
#include "pin_mux.h"
#include "clock_config.h"
#include "LPC54114_cm4.h"
/* TODO: insert other include files here. */
#include "fsl_spi.h"
#include "fsl_gpio.h"
/* TODO: insert other definitions and declarations here. */
spi_slave_handle_t handle;
static volatile bool slaveFinished = false;
static void slaveCallback(SPI_Type *base, spi_slave_handle_t *slaveHandle, status_t status, void *userData)
slaveFinished = true;
int main(void) {
unsigned int pin_bleu = 9;
unsigned int port = 1;
GPIO_PinWrite(GPIO, port, pin_bleu, 0);
unsigned char tx = 0x2C; //44
unsigned char rx;
/* Init board hardware. */
BOARD_InitBootPins();
BOARD_InitBootClocks();
BOARD_InitBootPeripherals();
spi_transfer_t xfer = {0};
xfer.txData = &tx;
xfer.rxData = ℞
xfer.dataSize = 1;
SPI_SlaveTransferCreateHandle(SPI_1_PERIPHERAL, &handle, slaveCallback, NULL);
SPI_SlaveTransferNonBlocking(SPI_1_PERIPHERAL, &handle, &xfer);
while (slaveFinished != true){}
if( rx == 0xAB){
GPIO_PinWrite(GPIO, port, pin_bleu, 1);
xfer.txData = ℞
xfer.rxData = ℞
xfer.dataSize = 1;
if( rx == 0x8){
while(1){}
return 0 ;
I thing I am missing something, but I am currently completely lost
Thank you very much in advance for your help
Regards,
Hugo
