Topic: Multiple Software Serial (Read 1 time) previous topic - next topic
mattcf
May 31, 2011, 07:12 am Last Edit: May 31, 2011, 07:18 am by mattcf Reason: 1
I am trying to like 3 arduino boards (1 main board and to breadboarded arduinos I built)  Is it possible to use multiple software serials to link the 2 breadboards to the Arduino Main board.
The 2 breadboards are collecting data that I want the mainboard to handle.
CrossRoads
mattcf
How would I go about doing it then (just the basics)
CrossRoads
Similar to regular serial:
Serial.begin(speed);
Softserial1.beging(speed);  or along those lines - search the forum for NewSoftSerial, you will find examples, need to define the pins used, etc.
Softserial2.begin(speed);
PaulS
Only one instance of NewSoftSerial can be active (buffering incoming data) at one time. So, it will only be possible to do what you want if you have handshaking implemented. That is, the master activates one instance of NewSoftSerial and tells the slave to send data. Then, the master activates the other instance of NewSoftSerial and tells the other slave to send data.
Slaves store data between uploads, and send everything they have buffered when called.
mattcf
Thank you for helping, I think I got it working now.  There was not alot of information I could find about using multiple Software Serials.
