gfvalvo:
Have you looked at the library's source code? Excerpt from LowPower.h:
#elif defined (__arm__)
#if defined (SAMD21G18A)
void idle(idle_t idleMode);
void standby();
#else
#error "Please ensure chosen MCU is ATSAMD21G18A."
#endif
#else
Also, there's an example specifically for SAMD21: "standbyExternalInterruptSAMD21.ino"
Doesn't seem like you've put much effort into this.
Dear gfvalvo,
Could you maybe have a look :)? I am already quite desperate since I have been trying to get the ItsyBitsy work with a low power library and an external interrupt that is provided by a DS3231 Real Time Clock. The code and the interrupt (each minute) works fine if i do not put any low power mode in the code. When I call the low power mode from either of one of these libraries:
- rocketscream:
GitHub - rocketscream/Low-Power: Low Power Library for Arduino
- Arduino Low Power:
Arduino Low Power - Arduino Reference
- RTCZero - Arduino Libraries
the MCU never comes back from sleep. Please have a look at my code below. The external interrupt calls an InterruptServiceRoutine that sets an alarm flag to true. The loop function then just sets the alarm flag to false and calls the handlealarm function. I have also tried to use CHANGE and LOW for the attach.Interrupt but the MCU still does not come back from sleep mode.
Where shall I call the sleep mode? I think the problem lies somewhere else besides the position of the sleep mode.
Please see my code below:
#include <RTCZero.h> //library for setting the real time clock on the MCU board, can also be used for low power modes
RTCZero rtc; //object definition
#include <Wire.h> //library for I2C connection
#include <OneWire.h> //library for the temperature sensor
#include <LowPower.h> //rocketscream library
//#include <SoftwareWire.h>
#include <RtcDS3231.h> //RTC library clock that sets the RTC alarm and RTC time
#include <DallasTemperature.h> //DS18 digital temperature library
//#include <ArduinoLowPower.h>
#define _BV(b) (1UL << (b)) //required for the Rtc2 wire definition
RtcDS3231<TwoWire> Rtc2(Wire);
volatile boolean alarm = 1;
//setting of the internal MCU clock using the RTCzero library
const byte seconds = 0;
const byte minutes = 20;
const byte hours = 15;
const byte days = 21;
const byte months = 7;
const byte years = 19;
const byte interruptPin = 11;
delay(5000); //delay to get the chip programmed
pinMode(interruptPin, INPUT_PULLUP);
attachInterrupt(digitalPinToInterrupt(interruptPin), handleInterrupt, CHANGE);
//Section for RTCzero library that sets the internal time of the MCU and puts the MCU to sleep via standbyMode();
rtc.begin();
rtc.setTime(hours, minutes, seconds);
rtc.setDate(days, months, years);
//rtc.setAlarmTime(00, 00, 10); //
//rtc.enableAlarm(rtc.MATCH_HHMMSS);
//rtc.attachInterrupt(ISR);
//extInterrupt(11); //creates an interrupt source on external pin
Rtc2.Begin();
RtcDateTime compiled = RtcDateTime(__DATE__, __TIME__);
Rtc2.SetDateTime(compiled);
RtcDateTime now = Rtc2.GetDateTime();
Rtc2.Enable32kHzPin(false);
Rtc2.SetSquareWavePin(DS3231SquareWavePin_ModeAlarmBoth);
RtcDateTime alarmTime = now + 88; // into the future
DS3231AlarmOne alarm1(
alarmTime.Day(),
alarmTime.Hour(),
alarmTime.Minute(),
alarmTime.Second(),
DS3231AlarmOneControl_HoursMinutesSecondsMatch);
Rtc2.SetAlarmOne(alarm1);
DS3231AlarmTwo alarm2(
0,
0,
0,
DS3231AlarmTwoControl_OncePerMinute);
Rtc2.SetAlarmTwo(alarm2);
Rtc2.LatchAlarmsTriggeredFlags();
if (alarm == true) {
handleAlarm();
// LowPower.standby();
void handleAlarm() {
alarm = false;
RtcDateTime timestamp = Rtc2.GetDateTime();
Serial.print("time interrupt at: ");
char time[10];
sprintf(time, "%d:%d:%d",
timestamp.Hour(),
timestamp.Minute(),
timestamp.Second()
Serial.println(time);
void handleInterrupt() {
alarm = true;
