Topic: Resistor for 8 pixel LED strip (Read 3401 times) previous topic - next topic
Mkstrawn
Good day,
I'll start by saying I am very novice and this is my first project ever. I'm learning on the fly.
I am running a 6V 2812b LED strip with 8 pixels in a "chase" sequence.
Power = (2) 3V lithium 123 batteries.
Driver = ATTINY85 that I've programmed with an Arduino Uno.
I plan on moving from breadboard to PCB soon, and would like to have custom PCB built. Before I do that, my question is:
Do I need a resistor? and if so, where do I run it?
The 2812B has a 6V connection, Ground, and Clock. So I am trying to learn WHERE to add the resistor in between the ATTINY85 and the strip, and also if there is anything I am missing before I solder into a PCB.
Thanks for your Help!
Mike
lastchancename
#1
Jul 21, 2019, 09:44 am Last Edit: Jul 21, 2019, 09:45 am by lastchancename
You may want to check the WS2812 data sheet.
Experienced responders have a nose for laziness, (they were beginners once)... Sure, there are trolls, chest-beaters, and pretenders - but the help you'll get here is about as good as it gets - if you try to help youself!.
Hiddenvision
#2
Jul 24, 2019, 04:14 pm Last Edit: Jul 24, 2019, 04:25 pm by Hiddenvision
It is said that you should put a resistor between the output data of the Arduino and the input of the led string.
WHY.? The data input on the leds has no protection and only needs a tiny bit of current to make it work.
And yes watch out for the 6v, it is a little high (20%) 5v is better.!
