Topic: Can I have an LED sequence running alongside a FADE ? (Read 94 times) previous topic - next topic
campbeda
Hi..
I hope someone can help. Also, I hope that I can explain it correctly..
Thanks for having a look!
I have a number of LEDs flashing - they use the following code so that they can independently flash in their own specific sequence...
Code: [Select]
const byte LEDAPin = 12;
const byte LEDBPin = 10;
pinMode(LEDAPin, OUTPUT);
pinMode(LEDBPin, OUTPUT);
SequenceRunA(LEDAPin);
SequenceRunB(LEDBPin);
void SequenceRunA(const byte pin)
const int sequence[][2] =
{HIGH, 200},
{LOW, 200}
const byte sequenceLength = sizeof sequence / sizeof sequence[0];
static unsigned long intervalStart = 0;
static unsigned long interval;
static byte index = 0;
if (intervalStart == 0)
digitalWrite(pin, sequence[index][0]);
interval = sequence[index][1];
intervalStart = currentMillis;
if (currentMillis - intervalStart >= interval)
index = (index + 1) % sequenceLength;
//END OF SEQUENCE A
void SequenceRunB (const byte pin)
{LOW, 400},
{HIGH, 200}
I also want to have another LED follow it's own sequence... it would be a simple FADE sequence, as shown below... but my question is... Can I have BOTH of these codes running alongside each other. ie. Can I have a fading LED sequence running alongside the SequenceRun?
THANKS!
Code: [Select]
int ledPin = 11;    // LED connected to digital pin 11
  for (int fadeValue = 0 ; fadeValue <= 100; fadeValue += 1)
    analogWrite(ledPin, fadeValue);
    delay(1);
  for (int fadeValue = 100 ; fadeValue >= 0; fadeValue -= 1
    delay(5
  delay (500);
    delay(1);
    delay(5
  delay (1000);
UKHeliBob
Quote
Yes, but you need to eliminate the delay()s and use millis() for timing throughout
Please do not send me PMs asking for help.  Post in the forum then everyone will benefit from seeing the questions and answers.
campbeda
Thanks for your reply.....
Yeah... Thats where my problem lies... I don't understand how to replace the (delay) with (millis)...
Should I try to make the FADE code a SequenceRun in itself?? That is way above my ability...uh oh...
blh64
Yes, make another copy of your SequenceRun function and call it SequenceFade and then you have to step through each of your for loops and delays like this (untested)
Code: [Select]
const byte ledPin = 11;    // LED connected to digital pin 11
  SequenceFade(ledPin);
    {HIGH, 200},
    {LOW, 200}
//END OF SEQUENCE A
    {LOW, 400},
    {HIGH, 200}
void SequenceFade(const byte pin)
  static int fadeValue = 0;
    analogWrite(pin, fadeValue);
    interval = 1;
    switch (index)
      case 0:   // counting up
        interval = 1;
        fadeValue++;
        if (fadeValue > 100)
          index++;
          fadeValue = 100;
      case 1:   // counting down
        interval = 5;
        fadeValue--;
        if (fadeValue < 0)
          index++;
          fadeValue = 0;
      case 2:   // pause
        interval = 500;
        index++;
      case 3:   // counting up
        interval = 1;
        fadeValue++;
          index++;
          fadeValue = 100;
      case 4:   // counting down
        interval = 5;
        fadeValue--;
        if (fadeValue < 0)
          index++;
          fadeValue = 0;
      case 5:   // pause
        interval = 1000;
        index = 0;  // start over
campbeda
You, are an absolute GENIUS!!
Thank you so much for your help...
What a super way to do it... It is EXACTLY as I needed it. I would never have figured it out myself... my head starts to turn to mush  :smiley-cry:
Sincere Thanks
Dara
