Topic: Using the receiver signal to activate codes (Read 1 time) previous topic - next topic
Beginner020
Hello,
I'm quite new to script writing, so I would strugle with harder codes than controlling servos, LEDs etc.
I want to make a code that would be activated by certain strength of RC car receiver throttle signal(the code would activate at certain amount of RPMs and stop if lower). But I don't know how to write it. :(
Please help with that.
wvmarle
In loop():
Code: [Select]
if (rpm > thresholdValue) {
   // do stuff for high rpm
where rpm is the latest rpm reading,
Quality of answers is related to the quality of questions. Good questions will get good answers. Useless answers are a sign of a poor question.
wvmarle
Can you read that signal with an Arduino and does it provide an rpm value?
If so: yes.
Hiddenvision
You have two clear options.
Either monitor the PWM signal on the servo to give you a throttle position.
https://www.electronoobs.com/eng_robotica_tut9_1.php
Or put a small sensor on the output of the motor to give actual RPM.
https://www.instructables.com/id/Measure-RPM-DIY-Portable-Digital-Tachometer/
