Topic: 9 Axis motion Shield : BNO055 (Read 718 times) previous topic - next topic
Hardach
Jul 22, 2019, 09:44 pm Last Edit: Jul 22, 2019, 09:58 pm by Hardach
Hello,
my question is simple: has anyone been able to operate this shield with a UNO rev3 please?
I only get values at 0. I tried a lot of examples provided, the program compiles and runs well but the values returned are always at 0: rotation angles, acceleration ...
here is a sample code:
Code: [Select]
#include "NAxisMotion.h"        //Contains the bridge code between the API and the Arduino Environment
#include <Wire.h>
NAxisMotion mySensor;         //Object that for the sensor
unsigned long lastStreamTime = 0;     //To store the last streamed time stamp
const int streamPeriod = 20;          //To stream at 50Hz without using additional timers (time period(ms) =1000/frequency(Hz))
void setup() //This code is executed once
  //Peripheral Initialization
  Serial.begin(115200);           //Initialize the Serial Port to view information on the Serial Monitor
  I2C.begin();                    //Initialize I2C communication to the let the library communicate with the sensor.
  //Sensor Initialization
  mySensor.initSensor();          //The I2C Address can be changed here inside this function in the library
  mySensor.setOperationMode(OPERATION_MODE_NDOF);   //Can be configured to other operation modes as desired
  mySensor.setUpdateMode(MANUAL); //The default is AUTO. Changing to MANUAL requires calling the relevant update functions prior to calling the read functions
  //Setting to MANUAL requires fewer reads to the sensor
void loop() //This code is looped forever
  if ((millis() - lastStreamTime) >= streamPeriod)
    lastStreamTime = millis();
    mySensor.updateEuler();        //Update the Euler data into the structure of the object
    mySensor.updateCalibStatus();  //Update the Calibration Status
    Serial.print("Time: ");
    Serial.print(lastStreamTime);
    Serial.print("ms ");
    Serial.print(" H: ");
    Serial.print(mySensor.readEulerHeading()); //Heading data
    Serial.print("deg ");
    Serial.print(" R: ");
    Serial.print(mySensor.readEulerRoll()); //Roll data
    Serial.print("deg");
    Serial.print(" P: ");
    Serial.print(mySensor.readEulerPitch()); //Pitch data
    Serial.print(" A: ");
    Serial.print(mySensor.readAccelCalibStatus());  //Accelerometer Calibration Status (0 - 3)
    Serial.print(" M: ");
    Serial.print(mySensor.readMagCalibStatus());    //Magnetometer Calibration Status (0 - 3)
    Serial.print(" G: ");
    Serial.print(mySensor.readGyroCalibStatus());   //Gyroscope Calibration Status (0 - 3)
    Serial.print(" S: ");
    Serial.print(mySensor.readSystemCalibStatus());   //System Calibration Status (0 - 3)
And the result :
Time: 7736ms  H: 0.00deg  R: 0.00deg P: 0.00deg  A: 0 M: 0 G: 0 S: 0
Time: 7756ms  H: 0.00deg  R: 0.00deg P: 0.00deg  A: 0 M: 0 G: 0 S: 0
Time: 7776ms  H: 0.00deg  R: 0.00deg P: 0.00deg  A: 0 M: 0 G: 0 S: 0
Time: 7796ms  H: 0.00deg  R: 0.00deg P: 0.00deg  A: 0 M: 0 G: 0 S: 0
Time: 7816ms  H: 0.00deg  R: 0.00deg P: 0.00deg  A: 0 M: 0 G: 0 S: 0
Time: 7836ms  H: 0.00deg  R: 0.00deg P: 0.00deg  A: 0 M: 0 G: 0 S: 0
Time: 7856ms  H: 0.00deg  R: 0.00deg P: 0.00deg  A: 0 M: 0 G: 0 S: 0
Time: 7876ms  H: 0.00deg  R: 0.00deg P: 0.00deg  A: 0 M: 0 G: 0 S: 0
Time: 7896ms  H: 0.00deg  R: 0.00deg P: 0.00deg  A: 0 M: 0 G: 0 S: 0
Time: 7916ms  H: 0.00deg  R: 0.00deg P: 0.00deg  A: 0 M: 0 G: 0 S: 0
Time: 7936ms  H: 0.00deg  R: 0.00deg P: 0.00deg  A: 0 M: 0 G: 0 S: 0
Time: 7956ms  H: 0.00deg  R: 0.00deg P: 0.00deg  A: 0 M: 0 G: 0 S: 0
Time: 7976ms  H: 0.00deg  R: 0.00deg P: 0.00deg  A: 0 M: 0 G: 0 S: 0
Precision: I did not do any particular wiring, I just connected the shield on the arduino.
Also, i used I2C scanner, and nothing is detected, it seems that shield not responding. What's your opinion about that ?
Thanks for any answer
jremington
#1
Jul 22, 2019, 10:21 pm Last Edit: Jul 22, 2019, 10:36 pm by jremington
Thanks for posting your code correctly!
Quote
That means no I2C device is connected to the I2C bus. Since the BNO055 is an I2C device*, it is not connected, not configured properly or not working.
Post a link to the product page for the "shield".
*in principle, there are two data connection options: I2C or UART serial. Make sure the correct one is selected.
jremington
#3
Jul 23, 2019, 12:27 am Last Edit: Jul 23, 2019, 12:29 am by jremington
I looked through the product page, and there seems to be no documentation at all for this product except a schematic diagram.
I would assume that it doesn't work and contact the seller for a remedy.
You are much better off buying a sensor like that from Pololu or Adafruit, companies that support their products with documentation. A bulky shield is in any case a poor choice for a motion sensor, as it is inconvenient for use in a robot.
gbafamily
meltDown
... and moreover needs an Uno to plug it on top of.
Hardach
Hello,
thank you all
@gbafamily : this the files i use.
@jremington & meltDown : yes next time i will probably go to adafruit.
For the time, i'm in touch with store support, they must send me technical instructions and code to test.
to be continued… i will inform you of the result
David
Hardach
Hi there,
my problem has been solved by arduino store support, thanks to them.
The pb was i didn't use the right révision of NaxisMotion and/or BNO055 libraries.
The only one i found was on Github but it's not the right version.
The support sent me a direct link to a ZIP file. Here is the link, but i think it's temporary link.
https://arduino.zendesk.com/attachments/token/p1ZTvzQ5TvSIvGOHhImyhCPey/?name=BigCompilationExample.zip
Thank you all !
David.
