Topic: Library meant for an Arduino or Nucleo board? Then, error: NODE_F207ZG not found (Read 89 times) previous topic - next topic
Maybe this isn't a programming question: is this library meant for a Nucleo board?
I have a Nucleo-F767ZI. I'm using the Arduino IDE because it's what I know and the STMcube IDE is confusing af.
This is the error:
Code: [Select]
Arduino: 1.8.9 (Windows 7), Board: "Nucleo-144, Nucleo F207ZG, Mass Storage, Enabled (generic 'Serial'), None, Low/Full Speed, Smallest (-Os default), Newlib Nano (default)"
A subdirectory or file sketch already exists.
Sketch uses 34916 bytes (3%) of program storage space. Maximum is 1048576 bytes.
Global variables use 1348 bytes (1%) of dynamic memory, leaving 129724 bytes for local variables. Maximum is 131072 bytes.
NODE_F207ZG not found. Please ensure the device is correctly connected.
An error occurred while uploading the sketch
option enabled in File -> Preferences.
I tried downloading these:
  • STM32CubeExpansion-SPN2_V1.1.0 package
  • stsw-link007
  • stsw-link008
  • stsw-link009
The executable for the (link009) fails to install the USB driver.
I just needed to select the right "Board part number" in the Tools Menu.
Problem solved.
