Topic: Escape codes for serial monitor (Read 927 times) previous topic - next topic
unclejuice
Can the serial monitor be designed so that it accepts Escape codes?
sterretje
If you're asking if Serial Monitor supports it, the answer is no.
If this question is a request, you should log a request on github.
My view
Serial Monitor is a debug tool and hence does not have a need for it. Use a real terminal program if you need support for ansi escape sequences.
If you understand an example, use it.
If you don't understand an example, don't use it.
Electronics engineer by trade, software engineer by profession. Trying to get back into electronics after 15 years absence.
Robin2
Use a terminal emulator program such as PuTTY or Realterm. I use minicom on Linux.
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
