Topic: RC Plane Library (ArdUAV) (Read 101 times) previous topic - next topic
Power_Broker
Hello all,
Once in a while I find hobbyists and students interested in making an Arduino-based RC airplane. Myself being one of these, I've designed, wrote, and tested a new library to make the software side of Arduino RC planes easier.
****Youtube of RC plane flight with ArdUAV library****
Link to the (extensive) build-log of the plane in the above vid
ArdUAV is an Arduino compatible C++ library that can easily be configured and used to control a completely Arduino-based RC airplane and transmitter. ArdUAV will handle all the background processing necessary to keep your plane flying in as little as 5-10 lines of sketch code. In addition to abstracting flight functions, it also provides transparency to all sensor outputs and servo commands. This allows you to write your own custom flight controller code in your sketch (i.e. GPS waypoint flying, ILS, camera gimbal control, etc) easily and with great readability.
Here is an example of the hand controller code:
Code: [Select]
#include "GS_Tools.h"
  //initialize the core ground station software class
  myGS.begin();
  //determine each command value based off GS sensor data and send commands to plane
  myGS.computeAndSendCommands();
  //send data to datalogging computer via debugging port
  myGS.sendTelem();
And here is an example of the flight controller code:
Code: [Select]
#include "IFC_Tools.h"
  //initialize the core flight controller software class
  myIFC.begin();
  //get GPS data
  if(myIFC.grabData_GPS())
    //optional debugging prints
    /*IFC_DEBUG_PORT.print("Latitude:\t"); IFC_DEBUG_PORT.println(myIFC.telemetry.latitude, 5);
    IFC_DEBUG_PORT.print("Longitude:\t"); IFC_DEBUG_PORT.println(myIFC.telemetry.longitude, 5);
    IFC_DEBUG_PORT.print("UTC_year:\t"); IFC_DEBUG_PORT.println(myIFC.telemetry.UTC_year);
    IFC_DEBUG_PORT.print("UTC_month:\t"); IFC_DEBUG_PORT.println(myIFC.telemetry.UTC_month);
    IFC_DEBUG_PORT.print("UTC_day:\t"); IFC_DEBUG_PORT.println(myIFC.telemetry.UTC_day);
    IFC_DEBUG_PORT.print("UTC_hour:\t"); IFC_DEBUG_PORT.println(myIFC.telemetry.UTC_hour);
    IFC_DEBUG_PORT.print("UTC_minute:\t"); IFC_DEBUG_PORT.println(myIFC.telemetry.UTC_minute);
    IFC_DEBUG_PORT.print("UTC_second:\t"); IFC_DEBUG_PORT.println(myIFC.telemetry.UTC_second);
    IFC_DEBUG_PORT.print("Speed Over Ground:\t"); IFC_DEBUG_PORT.println(myIFC.telemetry.speedOverGround, 3);
    IFC_DEBUG_PORT.print("Course Over Ground:\t"); IFC_DEBUG_PORT.println(myIFC.telemetry.courseOverGround, 3);
    IFC_DEBUG_PORT.println();*/
  //get IMU data
  if(myIFC.grabData_IMU())
    /*IFC_DEBUG_PORT.print("Pitch Angle:\t"); IFC_DEBUG_PORT.println(myIFC.telemetry.pitchAngle, 5);
    IFC_DEBUG_PORT.print("Roll Angle:\t"); IFC_DEBUG_PORT.println(myIFC.telemetry.rollAngle, 5);
    //IFC_DEBUG_PORT.print("Course Angle:\t"); IFC_DEBUG_PORT.println(myIFC.telemetry.courseAngle, 5);
  //get LiDAR altimeter data
  if(myIFC.grabData_LiDAR())
    /*IFC_DEBUG_PORT.print("Converted Altitude:\t"); IFC_DEBUG_PORT.println(myIFC.telemetry.convertedAltitude);
  //get airspeed data from the pitot tube
  if(myIFC.grabData_Pitot())
    /*IFC_DEBUG_PORT.print("Converted Airspeed:\t"); IFC_DEBUG_PORT.println(myIFC.telemetry.velocity);
  //update all servo positions based on the new data
  myIFC.updateServos();
  //send the telemetry to the radio
  myIFC.sendTelem();
Both myGS and myIFC classes have public "telemetry" and "controlInputs" structs that provide the data transparency as described earlier. They are defined as:
Code: [Select]
//struct to store telemetry data
struct telemetry
float altitude;             //cm
float convertedAltitude;    //cm
float courseAngle;          //degrees
float rollAngle;            //degrees
float pitchAngle;           //degrees
float convertedRoll;        //radians
float convertedPitch;       //radians
float velocity;             //m/s
float latitude;             //dd
float longitude;            //dd
uint16_t UTC_year;          //y
uint16_t UTC_month;         //M
uint16_t UTC_day;           //d
uint16_t UTC_hour;          //h
uint16_t UTC_minute;        //m
uint16_t UTC_second;        //s
float speedOverGround;      //knots
float courseOverGround;     //degrees
} telemetry;
//struct to store control values (i.e. servo commands etc.)
struct controlInputs
bool limiter_enable; //enables and disables pitch and bank limiter
uint16_t pitch_command;
uint16_t roll_command;
uint16_t yaw_command;
uint16_t throttle_command;
uint16_t autopilot_command;
uint16_t limiter_command;
uint16_t landingGear_command;
uint16_t flaps_command;
} controlInputs;
Let me know what y'all think and if there are any improvements to be made!
"The desire that guides me in all I do is the desire to harness the forces of nature to the service of mankind."
   - Nikola Tesla
