Topic: duinoWitchery hd44780 Library - Backpack LCD & Wemos D1 Mini - ESP8266 (Read 388 times) previous topic - next topic
jlmyra
I am trying to use your library as I am interested in taking advantage of the linewrap functionality. I can make the example sketch work fine on a 4x20 backpack LCD. When I add ESP wifi connectivity to the sketch I am unable to get a wifi connection. Is there a reason why the library would prevent a wifi connection on esp8266?
Thanks!
Code: [Select]
// vi:ts=4
// LineWrap - simple demonstration of automatic linewrap functionality
// Created by Bill Perry 2017-05-10
// bperrybap@opensource.billsworld.billandterrie.com
// This example code is unlicensed and is released into the public domain
// This sketch is for LCD modules that have a native I2C interface such as
// PCF2119x, PCF2116, or certain RayStar LCDs rather than those LCD modules that
// use an i/o expander chip based based backpack.
// NOTE:
//  These devices usually need external pullups as they typically are not on
//  the module.
// WARNING:
//  Use caution when using 3v only processors like arm and ESP8266 processors
//  when interfacing with 5v modules as not doing proper level shifting or
//  incorrectly hooking things up can damage the processor.
// Sketch demonstrates hd44780 library automatic line wrapping functionality.
// Background:
// hd44780 LCDs do not use linear continuous memory for the characters
// on the lines on the display.
// This means that simply sending continuous characters to the
// display will not fill lines and wrap appropriately as might be expected.
// The hd44780 library solves this issue by adding a line wrapping capability
// in s/w that can be enabled & disabled.
// This allows the host to send characters to the display continuously and they
// will wrap to the next lower line when the end of the visible line has been
// reached. When on the bottom line it will wrap back to the top line.
// (Configure LCD_COLS & LCD_ROWS if desired/needed)
// Expected behavior of the sketch:
// - display a banner announcing the test.
// - print the configured LCD geometry
// - print a long text string to demostrate automatic line wrapping
// - print lots of characters (slowly) to show how the full wrapping works.
// (loop)
// If initialization of the LCD fails and the arduino supports a built in LED,
// the sketch will simply blink the built in LED with the initalization error
// code.
// Special note for certain 16x1 displays:
// Some 16x1 displays are actually a 8x2 display that have both lines on
// a single line on the display.
// If you have one of these displays, simply set the geometry to 8x2 instead
// of 16x1.
// In normal sketches, lineWrap() mode will allow this type of display to
// properly function as a 16x1 display in that it will allow printing up to
// 16 characters on the display without having to manually set the cursor
// position to print the right characters on the half of the display.
// However, when using this 8x2 display as a 16x1 display,
// scrollDisplayLeft() and scrollDisplayRight() will not work as intended.
// They will shift the two halves of the display rather than the entire display.
// This is because the hd44780 chip is doing the shift and chip is hard coded
// internally for two lines.
// include the needed headers.
#include <Wire.h>
#include <hd44780.h>            // main hd44780 header
#include <hd44780ioClass/hd44780_I2Cexp.h>  // i2c LCD i/o class header
#include <ESP8266WiFi.h>
#include <WiFiClient.h>
WiFiClient client;
const char *ssid = "XXXXXXXXXXX";
const char *password = "XXXXXXXXX";
// Note, i2c address can be specified or automatically located
// If you wish to use a specific address comment out this constructor
// and use the constructor below that specifies the address
// declare the lcd object for auto i2c address location
//hd44780_I2Clcd lcd;
// enter address of LCD.
// Addresses seen so far include:
// - 0x3a, 0x3b (PCF2119x)
// - 0x3c (unknwon chip)
// - 0x3d (unknwon chip)
// - 0x3e (unknwon chip)
// - 0x3f (unknwon chip)
// declare i2c address and constructor for specified i2c address
//const int i2c_addr = 0x27;
//hd44780_I2Cexp lcd(i2c_addr, I2Cexp_BOARD_LCM1602); // use device at this address
hd44780_I2Cexp lcd;
// LCD geometry
// while 16x2 will work on most displays even if the geometry is different,
// for actual wrap testing of a particular LCD it is best to use the correct
// geometry.
const int LCD_COLS = 20;
const int LCD_ROWS = 4;
Serial.begin(230400);  //Fast to stop it holding up the stream
int status;
  // initialize LCD with number of columns and rows:
  // hd44780 returns a status from begin() that can be used
  // to determine if initalization failed.
  // the actual status codes are defined in <hd44780.h>
  status = lcd.begin(LCD_COLS, LCD_ROWS);
  if(status) // non zero status means it was unsuccesful
    status = -status; // convert negative status value to positive number
    // begin() failed so blink error code using the onboard LED if possible
    hd44780::fatalError(status); // does not return
  // turn on automatic line wrapping
  // which automatically wraps lines to the next lower line and wraps back
  // to the top when at the bottom line
  // NOTE:
  // noLineWrap() can be used to disable automatic line wrapping.
  // _write() can be called instead of write() to send data bytes
  // to the display bypassing any special character or line wrap processing.
  lcd.lineWrap();
  const char* deviceName = "XXXXXXX";
 WiFi.disconnect();  //Prevent connecting to wifi based on previous configuration
 WiFi.hostname(deviceName);
 WiFi.mode(WIFI_STA); //This line hides the viewing of ESP as wifi hotspot
 //WiFi.config(staticIP, gateway, subnet);
 WiFi.begin(ssid, password);
 checkWiFi();
  lcd.clear();
  lcd.print("WrapTest");
  delay(2000);
  lcd.clear();
  //print the configured LCD geometry
  lcd.print(LCD_COLS);
  lcd.print("x");
  lcd.print(LCD_ROWS);
  delay(3000);
  lcd.clear();
  // print a long text string
  // without line wrapping enabled, the text would not wrap properly
  // to the next line.
  if(LCD_COLS == 8)
    lcd.print("A long text line");
    lcd.print("This is a very long line of text");
  delay(3000);
  lcd.clear();
  // now print 2 full displays worth of characters to show
  // the full wrapping.
  lcd.cursor(); // turn on cursor so you can see where it is
  char c = '0'; // start at the character for the number zero
  for(int i = 2*LCD_COLS*LCD_ROWS; i; i--)
    lcd.print(c++);
    delay(200); // slow things down to watch the printing & wrapping
    if(c > 0x7e) // wrap back to beginning of printable ASCII chars
      c = '!';
  delay(3000);
  lcd.noCursor(); // turn off cursor
void checkWiFi(){
    if(WiFi.status() != WL_CONNECTED){
    Serial.print("Attempting to connect to wifi: "); Serial.println(ssid);
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.print("  Attempting WiFi   ");
    lcd.setCursor(0,1);
    lcd.print("     connection     ");
    int x = 1;
    while(WiFi.status() != WL_CONNECTED){
      if ( x == 11) {
        while (1);
    lcd.setCursor(0,3);
    lcd.print("attempt: ");
    lcd.print(" ");
    lcd.setCursor(10,3);
    lcd.print(x);
    WiFi.begin(ssid, password);  // Connect to WPA/WPA2 network. Change this line if using open or WEP network
    Serial.print(x);
    x = x + 1;
//Connect or reconnect to WiFi
if(WiFi.status() == WL_CONNECTED) {
    Serial.print("WiFi CONNECTED; ");
Paul__B
OK, two things to start with.
Firstly, separate the code.  Does the WiFi code run without all the LCD stuff (and I mean all - just comment it all out)?
Secondly - do not expect code to work if you include delay() functions.  Go find the instructions on understanding "Blink without delay" in the "Project Guidance" forum.
bperrybap
I have many projects that use wifi on the esp8266 platform and the hd44780 hd44780_I2Cexp i/o class.
Some use the WiFiManager and some don't.
I've not delved into your WiFi initialization code, but so far I've not seen/had any WiFi issues when using the LCD or when using delay(). The ESP core does all the necessary watchdog stuff in the delay() function to prevent a watchdog timeout.
--- bill
