Topic: Question about esp-01 and his usb adapter: Auto run after upload ? (Read 1 time) previous topic - next topic
atlas2003
Hello
I have this kind of usb adapter for esp-01:
https://www.google.com/search?q=usb+adapter+esp-01&rlz=1C5CHFA_enCA711CA711&source=lnms&tbm=isch&sa=X&ved=0ahUKEwiBufmA2tjjAhXuc98KHTmLC5oQ_AUIESgB&biw=1440&bih=740
I know that to upload a sketch on it, I have to put the GPIO0 pin grounded. The upload is working fine.
My question is:
After the upload, I have to manualy reset the esp in order to run the sketch.
Is there a way that the sketch start automaticly after the upload process ? It's not very easy to unplug, re-plug the usb each time I made a modification in the sketch.
Thank you
KASSIMSAMJI
you can flash your esp 8266 over the air with your browser (PC/phone)
open up Arduino IDE
go to to file>examples>esp8266httpupdateserver>webupdater
all you need is a bin file,
after you compile your sketch
'bin' can be located at
C:\Users\your_name\AppData\Local\Temp\arduino_build_765113\file_name.ino.bin ( on Windows )
in this way you don't have to plug in and out your esp01 to flash it
Expert To Be: Machine Learning And Computer/Machine Vision (ML/CV/MV)
atlas2003
Thk you for you answer. Yeah, I know the OTA. But for a super simple sketch, I don't want to bother to use OTA.
I've changed my hardware. I know use a wemos D1 which feature auto reset and auto program. Much more simple to use.
Have a good day.
