Topic: [Help] Circular LED Matrix for Railroad Signal Post (Read 741 times) previous topic - next topic
V4D3R
Jul 29, 2019, 01:16 am Last Edit: Jul 31, 2019, 07:28 pm by CrossRoads
Hello, I'm new to the forums and new to Arduino as a whole. I'm aware that the use of an Arduino can accomplish what I'm looking for but I need some help from you guys in terms of how to get it done. Basically I need to display different light signals on a signal post (think of it like a traffic light except with more combinations instead of just a simple red, yellow, and green). I've attached the two types of signals I want to display.
The pictures attached show two types of signals from two different railroads; the double head with multiple lights is from Amtrak and the triple head with single lights is from NJ Transit [NJT].
My plan is to make one signal post with three circular heads to avoid making two separate posts for the two types of signals. Each head will be filled with a circular LED matrix so that I can show both types of signals; ie: to display an Amtrak signal, a specific set of LEDs in the matrix would light up. To display an NJT signal, the entire circular head would light up.
How would I go about getting this started? Thank you in advance, anything helps.
larryd
No technical PMs.
If you are asked a question, please respond with an answer.
If you are asked for more information, please supply it.
If you need clarification, ask for help.
V4D3R
I'm good at 3D modeling things, I can follow instructions pretty well especially when they're visual. But yes, I'd like to create something like a 10-15" circular head
larryd
"10-15" circular head"
Is this for a model train?
No technical PMs.
V4D3R
No, this is for studying purposes in order to be able to recognize and verbally call out signals as they are presented, thus the 10-15" circular head size
larryd
The image offered in post #1 could be one of the actual lights in the matrix.
These can be made any colour.
However, simple LEDs might be best, i.e. Red and Green
The software would be simple to write depending on what you need.
No technical PMs.
larryd
No technical PMs.
V4D3R
https://imgur.com/LMbDgmU
I was looking to make something more along the lines of the image above; basically an array of RGB LEDs spaced about 2mm apart
larryd
That will certainly blind everyone.
No technical PMs.
V4D3R
Haha, yes it may seem like that but the real signal heads used in the field are much brighter and have to be visible from at least 500'-1000' away depending on the setting. That's why I'm opting for a 10" circular head as the signal post will be mounted outdoors to simulate real world viewing (during heavy rain, sleet, snow, fog, etc). I figure at least a 10" head with some bright LEDs would be viewable from a minimum of 100' in the right conditions.
Anyways, I'd like to know how I'd be able to control that matrix to display the two types of signals I mentioned above. Basically I'd want the entire head lit up for the NJT type and only specific parts for the Amtrak type. Would it be as simple as wiring up all the LEDs to power/arduino and controlling them? Sorry if I'm asking obvious questions, just need to be pointed in the right direction to get this project going. Thanks
noiasca
#10
Jul 29, 2019, 08:10 am Last Edit: Jul 29, 2019, 08:18 am by noiasca
first you have to take a hardware design decision, what LED's you will use.
If you decide for some kind of Neopixels, WS2812, APA106 ... it might get easier because they can be daisy chained.
Than lay your chain in your picture
Now you can number each LED from 0 .. 400 (just guessed)
Having a number for each LED you can design the pattern of your signs, adressing each lighted LED with a specified color. You might end up with a big array of numbers, each element containing LED & color.
E.g. a struct
keep in mind that you will need huge amount of RAM and/or Flash to store these pictures in your microcontroller.
Honestly - I wouldn't do this project with separate pixels.
Either I would
- use this simple module from post #1 or
- or search the largest neopixels module I could find
- or an old 4 to 3 monitor driven by a PC/raspberry. 4 to 3 should give you a fair chance to mask a circle in your desired size.
- Or even a 16 to 9 in portrait format could be used for 2 vertically aligned circles...
DE: Wie man Fragen postet:
1. was hat man (Sketch und Hardware)
2. was SOLL es machen
3. was macht es: IST (Fehlverhalten, Fehlermeldungen, Serial.Output ...)
4. Eine Frage stellen bzw. erklären was man erwartet
V4D3R
Want to stick to using LEDs and not monitors, how would I go about adding more RAM to the arduino? The LED I'm planning on using is a push through version based on neopixels WS2812 in order to have RGB through each individual bul
david_2018
Seems like a lot of your LEDs would be in positions that would never be used, unless you have other plans for the device.
Quote
Presumably there will just be circular groups of LEDs lit up in solid colors to simulate the real signs, so I wouldn't think it would be necessary to store the entire pixel pattern for each image.  You could have an array that gives the pixel positions for each "circle" that needs to be lit up, then another small array that gives the desired color pattern for each pattern that needs to be displayed on the sign.
V4D3R
For the two types of signals shown, the NJT variant will utilize all of the LEDs. However, later on the signal post will be used for other railroads signals as well since railroad signals aren't federally governed and there are many color/position combinations across the nation (USA). I just want to start out by using the two types mentioned above (Amtrak & NJT). I'm looking for an outline on how to get this done before I start so I know exactly what I need to do
david_2018
