Hey guys I am a total loss here. I'm trying to use the Parola Bluetooth control library to make a blue tooth connected sign. The libraries work great on my hardware except for when I try to use the Bluetooth sketch.
I have successfully connected and use my Bluetooth hardware using the Max matrix library so I know that my hardware is functioning properly. I'm trying to use the parola Bluetooth control sketch that's provided with the library. It loads successfully on my board but nothing else. What's interesting is when I run it configured for the Bluetooth 05 board nothing shows up on my display, but when I run it configured for the 06 board it says "setup" on my display. I tried connecting a 05 module and 06 module nothing. I've tried using different Arduino no boards nothing. I notice that my TX&RX lights do not light up on my Arduino board what I try transmitting Bluetooth.
I don't know if my problem is the software configuration or if it is in the app on my phone not configured properly. I'm using the Parola Control app.
I found another sketch online it seems to transmit to my board because my RX and TX light up.
Here it is:
// Program to demonstrate the MD_Parola library
// For every string defined by pc[] iterate through all combinations
// of entry and exit effects.
// Animation speed can be controlled using a pot on pin SPEED_IN
// NOTE: MD_MAX72xx library must be installed and configured for the LED
// matrix type being used. Refer documentation included in the MD_MAX72xx
// library or see this link:
// https://majicdesigns.github.io/MD_MAX72XX/page_hardware.html
#include <MD_Parola.h>
#include <MD_MAX72xx.h>
#include <SPI.h>
// Define the number of devices we have in the chain and the hardware interface
// NOTE: These pin numbers will probably not work with your hardware and may
// need to be adapted
#define MAX_DEVICES 4
#define CLK_PIN 13
#define DATA_PIN 11
#define CS_PIN 10
#define HARDWARE_TYPE MD_MAX72XX::ICSTATION_HW
// set to 1 if we are implementing the user interface pot
#define USE_UI_CONTROL 0
#if USE_UI_CONTROL
#define SPEED_IN A5
uint8_t frameDelay = 25; // default frame delay value
#endif // USE_UI_CONTROL
// Hardware SPI connection
MD_Parola P = MD_Parola(CS_PIN, MAX_DEVICES);
// Arbitrary output pins
// MD_Parola P = MD_Parola(DATA_PIN, CLK_PIN, CS_PIN, MAX_DEVICES);
#define SPEED_TIME 25
#define PAUSE_TIME 1000
// Turn on debug statements to the serial output
#define DEBUG 0
#if DEBUG
#define PRINT(s, x) { Serial.print(F(s)); Serial.print(x); }
#define PRINTS(x) Serial.print(F(x))
#define PRINTX(x) Serial.println(x, HEX)
#else
#define PRINT(s, x)
#define PRINTS(x)
#define PRINTX(x)
#endif
bool firsttime = true;
char c;
void Write(char *tulisan);
String stringOne;
char charBuf[200];
// Global variables
uint8_t curText;
char *pc[] =
uint8_t inFX, outFX;
textEffect_t effect[] =
PA_SCROLL_LEFT
#if USE_UI_CONTROL
void doUI(void)
// set the speed if it has changed
int16_t speed = map(analogRead(SPEED_IN), 0, 1023, 0, 250);
if (speed != (int16_t)P.getSpeed())
// P.setSpeed(speed); //UNCOMMENT these lines to use variable resistor connected to pin A5 as the scrolling speed controller (*)
// P.setPause(speed); //(*)
// frameDelay = speed; //(*)
int speed1 = 30; //COMMENT these lines to use variable resistor as the scrolling speed controller (**) <- the smaller the value, the faster scrolling speed would be
P.setSpeed(speed1); //(**)
P.setPause(speed1); //(**)
frameDelay = speed1; //(**)
PRINT("\nChanged speed to ", P.getSpeed());
char* string2char(String command){
if(command.length()!=0){
char *p = const_cast<char*>(command.c_str());
return p;
void setup(void)
#if USE_UI_CONTROL
pinMode(SPEED_IN, INPUT);
doUI();
P.begin();
P.setInvert(false);
P.displayText(pc[curText], PA_CENTER, SPEED_TIME, PAUSE_TIME, effect[inFX], effect[outFX]);
Serial.println("Mula");
while (Serial.available())
if (Serial.available() > 0)
firsttime = false;
stringOne = Serial.readString();
Serial.println(stringOne);
stringOne.toCharArray(charBuf, 200) ;
Serial.flush();
if (firsttime == false) Write(charBuf);
else Write("Welcome!");
#if USE_UI_CONTROL
doUI();
char *pc[] = {tulisan};
if (P.displayAnimate()) // animates and returns true when an animation is completed
// Set the display for the next string.
curText = (++curText);
P.setTextBuffer(pc[curText]);
// When we have gone back to the first string, set a new exit effect
// and when we have done all those set a new entry effect.
if (curText == 0)
outFX = (++outFX);
if (outFX == 0)
inFX = (++inFX);
if (inFX == 0)
P.setInvert(!P.getInvert());
P.setTextEffect(effect[inFX], effect[outFX]);
// Tell Parola we have a new animation
P.displayReset();
I can't post the original Parola sketch because I exceeded the text limit
Thanks for any help
