Topic: Loadcell not showing correct values in Windows (Read 127 times) previous topic - next topic
niterida
I have an Arduino Micro Pro and HX711 loadcell amp that appear to be working correctly using IDE calibrate. That is I can see values rising from 0 to over 30,000 when I press really really hard.
But when I look at in in DIVIEW or within my simracing game (Assetto Corsa) it goes from -32767 to +32767 with the slightest touch. Even just setting it down it goes to +32767 under its own weight !!
I have rebooted PC and reloaded the sketch but it hasn't made any difference.
Any ideas what could be wrong ?
Delta_G
Something is wrong with your code or your setup.  It makes for an interesting problem.  Perhaps someone who can see the code and the wiring setup can help.  Why you didn't supply that here so someone here can help you is beyond me.  Did you not want any help here?  You just wanted us to know that you have a problem?
|| | ||| | || | ||  ~Woodstock
Please do not PM with technical questions or comments.  Keep Arduino stuff out on the boards where it belongs.
ballscrewbob
@niterida
STOP CROSS POSTING.
Stick to your ORIGINAL THREAD
Next time you cross post there may be trouble.
Bob
It may not be the answer you were looking for but its the one I am giving based on either experience, educated guess, google or the fact that you gave nothing to go with in the first place so I used my wonky crystal ball.
