Topic: Prefference file loader (Read 475 times) previous topic - next topic
Hiddenvision
#15
Aug 11, 2019, 03:47 pm Last Edit: Aug 14, 2019, 06:13 am by Hiddenvision
did a few updates. (you click on the version number to autoupdate).
It now saves the menu and search options rather than always defaulting to original.
It also saves a projects.txt file to speed up loading rather than scanning the folders each startup.
I also added a Merge function for merging or replacing static preferences into the mix but I am still working on that bit, I don't need it but I can see it being useful one day.
Um not much else apart from fix all the things I found that nobody has commented about yet.
If you have questions or would like it to do something I had not considered then just shout.
If the program if failing to run due to missing ocx see later post for VB_OCX.zip
Hiddenvision
#16
Aug 13, 2019, 08:15 pm Last Edit: Aug 13, 2019, 08:18 pm by Hiddenvision
Oops,
I forgot to make available the two required VB6 OCX files.
That could bring a halt to the party.
Ocx files are best placed/unziped into the "windows/System32" folder.
However you may ALSO need to put them in windows/SysWOW64 folder.
I am being lazy by not creating an installation package, forgive me.
You can be lazy too and put them in the application folder but it is not good practice.
Then the FIRST time you run Arduino_pref.exe run it as administrator and the OCX files will auto register.
