Topic: arduino nano nrf24l01+ st7735s (Read 312 times) previous topic - next topic
SamRum
I am trying to connect the following devices to a Nano
nrf24l01+
st7735s
BMP280
It looks like the nrf24l01+and st7735s both use the same pins. Is it possible to redirect the pins to a different pin such as  the following
st7735s
pin 13 could be pin D6
pin 11 could be pin D5
if I am incorrect does anyone have a suggestion on how I should layout the pins connections?
From what I have read these devices use the following pins. if I am in correct with my pins usage please correct me.
nrf24l01+
ce - 3
cs - 4
mosi - 11
miso - 12
sck - 13
vcc - 3v
gnd - gnd
st7735s
a0 - 8
resist - 9
cs - 10
sda - 11
sck - 13
led+ - 3v
led- - gnd
BMP280
scl - A4
sda - A5
vcc - 3v
gnd - gnd
The end goal is to have two different devices. The sender will collect the temp every 30 seconds. After 5 minutes it will average the samples and transmit the data to the receiver and the receiver will display the temp for each receiver on the screen.
Device A receiver
Arduino nano
nrf24l01+
st7735s
Device B sender
Arduino pro mini
nrf24l01+
BMP280
raschemmel
Did you research these devices ?
Can you tell us what protocol they use ?
Grumpy_Mike
Quote
Is it a 5V nano?
If so you will need signal level converters to stop the 5V signal outputs from damaging the devices.
Quote
st7735s
No.
Both of those devices use an SPI interface, this is designed to allow the connection of many devices on the same set of wires. To use more than one device each one must have its own chip enable pin. This pin is put low before the software talks to the SPI bus so the chip knows it is about to be communicated with.
raschemmel
This is called a 'bus'.
"You're either on the bus or off the bus"
Ken Kesey
Grumpy_Mike
Might come as a surprise but I am from the UK and have no idea who Ken Kesey is or why he should say that.
Grumpy_Mike
raschemmel
#7
Aug 03, 2019, 03:57 pm Last Edit: Aug 03, 2019, 04:30 pm by raschemmel
Quote
Thanks, have a Kama point.
Thank you.
We're  all one.
Quote
The need for mystery is greater than the need for an answer.
Ken Kesey
