when compiling the MPU6050 examples that come with Jeff Rowberg library I now get an error. Could someone please guide me in correcting this issue. I have reinstalled IDE and libraries with no success. this was working on this machine last week and don,t know whats changed to cause this. below is the errors after trying to compile. thank you
In file included from C:\Users\grego\Documents\Arduino\libraries\MPU6050\Examples\MPU6050_DMP6\MPU6050_DMP6.ino:48:0:
C:\Users\grego\Documents\Arduino\libraries\MPU6050/MPU6050_6Axis_MotionApps20.h: In member function 'uint8_t MPU6050::dmpGetAccel(int32_t*, const uint8_t*)':
C:\Users\grego\Documents\Arduino\libraries\MPU6050/MPU6050_6Axis_MotionApps20.h:580:31: warning: left shift count >= width of type [-Wshift-count-overflow]
data[0] = ((packet[28] << 24) + (packet[29] << 16) + (packet[30] << 8) + packet[31]);
C:\Users\grego\Documents\Arduino\libraries\MPU6050/MPU6050_6Axis_MotionApps20.h:580:52: warning: left shift count >= width of type [-Wshift-count-overflow]
C:\Users\grego\Documents\Arduino\libraries\MPU6050/MPU6050_6Axis_MotionApps20.h:581:31: warning: left shift count >= width of type [-Wshift-count-overflow]
data[1] = ((packet[32] << 24) + (packet[33] << 16) + (packet[34] << 8) + packet[35]);
C:\Users\grego\Documents\Arduino\libraries\MPU6050/MPU6050_6Axis_MotionApps20.h:581:52: warning: left shift count >= width of type [-Wshift-count-overflow]
C:\Users\grego\Documents\Arduino\libraries\MPU6050/MPU6050_6Axis_MotionApps20.h:582:31: warning: left shift count >= width of type [-Wshift-count-overflow]
data[2] = ((packet[36] << 24) + (packet[37] << 16) + (packet[38] << 8) + packet[39]);
C:\Users\grego\Documents\Arduino\libraries\MPU6050/MPU6050_6Axis_MotionApps20.h:582:52: warning: left shift count >= width of type [-Wshift-count-overflow]
C:\Users\grego\Documents\Arduino\libraries\MPU6050/MPU6050_6Axis_MotionApps20.h: In member function 'uint8_t MPU6050::dmpGetQuaternion(int32_t*, const uint8_t*)':
C:\Users\grego\Documents\Arduino\libraries\MPU6050/MPU6050_6Axis_MotionApps20.h:604:30: warning: left shift count >= width of type [-Wshift-count-overflow]
data[0] = ((packet[0] << 24) + (packet[1] << 16) + (packet[2] << 8) + packet[3]);
C:\Users\grego\Documents\Arduino\libraries\MPU6050/MPU6050_6Axis_MotionApps20.h:604:50: warning: left shift count >= width of type [-Wshift-count-overflow]
C:\Users\grego\Documents\Arduino\libraries\MPU6050/MPU6050_6Axis_MotionApps20.h:605:30: warning: left shift count >= width of type [-Wshift-count-overflow]
data[1] = ((packet[4] << 24) + (packet[5] << 16) + (packet[6] << 8) + packet[7]);
C:\Users\grego\Documents\Arduino\libraries\MPU6050/MPU6050_6Axis_MotionApps20.h:605:50: warning: left shift count >= width of type [-Wshift-count-overflow]
C:\Users\grego\Documents\Arduino\libraries\MPU6050/MPU6050_6Axis_MotionApps20.h:606:30: warning: left shift count >= width of type [-Wshift-count-overflow]
data[2] = ((packet[8] << 24) + (packet[9] << 16) + (packet[10] << 8) + packet[11]);
C:\Users\grego\Documents\Arduino\libraries\MPU6050/MPU6050_6Axis_MotionApps20.h:606:50: warning: left shift count >= width of type [-Wshift-count-overflow]
C:\Users\grego\Documents\Arduino\libraries\MPU6050/MPU6050_6Axis_MotionApps20.h:607:31: warning: left shift count >= width of type [-Wshift-count-overflow]
data[3] = ((packet[12] << 24) + (packet[13] << 16) + (packet[14] << 8) + packet[15]);
C:\Users\grego\Documents\Arduino\libraries\MPU6050/MPU6050_6Axis_MotionApps20.h:607:52: warning: left shift count >= width of type [-Wshift-count-overflow]
C:\Users\grego\Documents\Arduino\libraries\MPU6050/MPU6050_6Axis_MotionApps20.h: In member function 'uint8_t MPU6050::dmpGetGyro(int32_t*, const uint8_t*)':
C:\Users\grego\Documents\Arduino\libraries\MPU6050/MPU6050_6Axis_MotionApps20.h:637:31: warning: left shift count >= width of type [-Wshift-count-overflow]
data[0] = ((packet[16] << 24) + (packet[17] << 16) + (packet[18] << 8) + packet[19]);
C:\Users\grego\Documents\Arduino\libraries\MPU6050/MPU6050_6Axis_MotionApps20.h:637:52: warning: left shift count >= width of type [-Wshift-count-overflow]
C:\Users\grego\Documents\Arduino\libraries\MPU6050/MPU6050_6Axis_MotionApps20.h:638:31: warning: left shift count >= width of type [-Wshift-count-overflow]
data[1] = ((packet[20] << 24) + (packet[21] << 16) + (packet[22] << 8) + packet[23]);
C:\Users\grego\Documents\Arduino\libraries\MPU6050/MPU6050_6Axis_MotionApps20.h:638:52: warning: left shift count >= width of type [-Wshift-count-overflow]
C:\Users\grego\Documents\Arduino\libraries\MPU6050/MPU6050_6Axis_MotionApps20.h:639:31: warning: left shift count >= width of type [-Wshift-count-overflow]
data[2] = ((packet[24] << 24) + (packet[25] << 16) + (packet[26] << 8) + packet[27]);
C:\Users\grego\Documents\Arduino\libraries\MPU6050/MPU6050_6Axis_MotionApps20.h:639:52: warning: left shift count >= width of type [-Wshift-count-overflow]
C:\Users\grego\Documents\Arduino\libraries\I2Cdev\I2Cdev.cpp:64:14: warning: #warning Using current Arduino IDE with Wire library is functionally limiting. [-Wcpp]
C:\Users\grego\Documents\Arduino\libraries\I2Cdev\I2Cdev.cpp:65:14: warning: #warning Arduino IDE v1.0.1+ with I2CDEV_BUILTIN_FASTWIRE implementation is recommended. [-Wcpp]
C:\Users\grego\Documents\Arduino\libraries\I2Cdev\I2Cdev.cpp:66:14: warning: #warning This I2Cdev implementation does not support: [-Wcpp]
C:\Users\grego\Documents\Arduino\libraries\I2Cdev\I2Cdev.cpp:67:14: warning: #warning - Timeout detection (some Wire requests block forever) [-Wcpp]
C:\Users\grego\Documents\Arduino\libraries\MPU6050/MPU6050.h:401:7: warning: type 'struct MPU6050' violates one definition rule [-Wodr]
class MPU6050 {
C:\Users\grego\Documents\Arduino\libraries\MPU6050\MPU6050.h:401:7: note: a different type is defined in another translation unit
class MPU6050 {
C:\Users\grego\Documents\Arduino\libraries\MPU6050/MPU6050.h:781:22: note: the first difference of corresponding definitions is field 'dmpPacketBuffer'
uint8_t *dmpPacketBuffer;
C:\Users\grego\Documents\Arduino\libraries\MPU6050\MPU6050.h:983:17: note: a field with different name is defined in another translation unit
uint8_t devAddr;
