Topic: Choosing LEDs and resistors for your arduino project (Read 673 times) previous topic - next topic
johnerrington
Aug 08, 2019, 09:18 am Last Edit: Aug 21, 2019, 11:19 am by johnerrington Reason: adding image
I found a lot of mis-information about driving LEDs - and a lot of questions. So I put together a page about it on my website.
If you find it useful, give me some karma; any feedback, questions or issues just let me know.
Edit: Thanks to those who responded with useful feedback, I've made some corrections and added an image.
Robin2
I don't like the idea that this website is being used to link to another website when there is no easy way to assess the quality of the information - it may be very good or it may be nonsense.
If the information is posted here it makes peer review much easier.
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
meltDown
I think the diagrams would be more accessible to the uninitiated if you had just showed an Arduino pin not a square with a & inside and 2 other wires sticking out the left.
And since you mentioned ports and their current, maybe you should mention what a port is and which pins constitute which ports; they're not just arbitrary groupings of 8 pins.
lastchancename
Good idea - but I also suggest moving that off-site content into this thread...
Ask the mods to delete the irrelevant posts after that is done.
You can put links - if necessary - inside your post (not just text)
http://www.skillbank.co.uk/arduino/led.htm
is the same as My Link
Experienced responders have a nose for laziness, (they were beginners once)... Sure, there are trolls, chest-beaters, and pretenders - but the help you'll get here is about as good as it gets - if you try to help youself!.
johnerrington
Thanks Robin2, good point. I've added an image from the start of the page.
Thanks lastchance; if you can explain to me how to get images to show in the right sequence WITHIN the text I'll do that when time permits.
lastchancename
This link tells everything about posting meaningful items
Posting pictures inline - there several posts (I cant spot them), but it's pretty easy...
Attach your image to the post as an 'attachment', then after initially posting the item, *copy the image URL* from the new post...
then go in and *edit the new post* - and add the picture within the body of the post using the [image] button or between img tags
