Topic: Color Sensor detecting colors but not giving good rgb values (Read 925 times) previous topic - next topic
marcopy
Hello Everybody! I made a color sensor and it detects colors fine. But on the serial monitor it does not send the good rgb values because most of the time, it sends 255,255,255 for every color!Here is the code:
Code: [Select]
int redPin = 11;
int greenPin = 10;
int bluePin = 6;
int S2 = 7;
int S3 = 8;
int outPin = 4;
int rColorStrength;
int gColorStrength;
int bColorStrength;
unsigned int pulseWidth;
  pinMode(redPin,OUTPUT);
  pinMode(greenPin,OUTPUT);
  pinMode(bluePin,OUTPUT);
  pinMode(S2,OUTPUT);
  pinMode(S3,OUTPUT);
  pinMode(outPin,INPUT);
  //red
  digitalWrite(S2,LOW);
  digitalWrite(S3,LOW);
  pulseWidth = pulseIn(outPin,LOW);
  rColorStrength = pulseWidth/400. -1;
  rColorStrength = (255-rColorStrength);
  //green
  digitalWrite(S2,HIGH);
  digitalWrite(S3,HIGH);
  gColorStrength = pulseWidth/400. -1;
  gColorStrength = (255-gColorStrength);
  //blue
  bColorStrength = pulseWidth/400. -1;
  bColorStrength = (255-bColorStrength);
  Serial.print(rColorStrength);
  Serial.print(" , ");
  Serial.print(gColorStrength);
  Serial.print(bColorStrength);
  Serial.println("");
  //red
  if(rColorStrength>gColorStrength && gColorStrength>bColorStrength){
    rColorStrength = 255;
    gColorStrength = gColorStrength/2.;
    bColorStrength = 0;
  if(rColorStrength>bColorStrength && bColorStrength>gColorStrength){
    bColorStrength = bColorStrength/2.;
    gColorStrength = 0;
  //green
  if(gColorStrength>rColorStrength && rColorStrength>bColorStrength){
    gColorStrength = 255;
    rColorStrength = rColorStrength/2.;
    bColorStrength = 0;
  if(gColorStrength>bColorStrength && bColorStrength>rColorStrength){
    rColorStrength = 0;
  //blue
  if(bColorStrength>rColorStrength && rColorStrength>gColorStrength){
    bColorStrength = 255;
    gColorStrength = 0;
  if(bColorStrength>gColorStrength && gColorStrength>rColorStrength){
    rColorStrength = 0;
  analogWrite(redPin, rColorStrength);
  analogWrite(greenPin, gColorStrength);
  analogWrite(bluePin, bColorStrength);
  delay(250);
Thanks
