Topic: Toreador March (Read 784 times) previous topic - next topic
uptownkitten
Greetings, I am wondering if anyone may, please help me with a little project I am doing. The project is supposed to play 'Toreador March' from FNAF, but I keep getting an error message saying "expected declaration before '}' token." Here is the code & hardware:
Code: [Select]
#include <pitches.h>
//Credit to : UptownKitten453 & the Arduino ToneMelody tutorial.
//https://www.arduino.cc/en/Tutorial/toneMelody
int melody[] = {
NOTE_F3, NOTE_C3, NOTE_F3, NOTE_C3, NOTE_F3, NOTE_C3, NOTE_F3, NOTE_C3, NOTE_F3, NOTE_C3, NOTE_F3, NOTE_C3, NOTE_F3, NOTE_C3, NOTE_F3, NOTE_C3, NOTE_G3, NOTE_C3, NOTE_F3, NOTE_E3, NOTE_D3, NOTE_G2, NOTE_C3, NOTE_B2, NOTE_D3
NOTE_B2, NOTE_G2, NOTE_A2, NOTE_D3, NOTE_F3, NOTE_A3, NOTE_A3, NOTE_E3, NOTE_Ab3, NOTE_E3,
NOTE_A3, NOTE_E3, NOTE_A3, NOTE_E3, NOTE_B2
int noteDurations[] = {
  4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4,4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4
void setup () {
   // iterate over the notes of the melody:
  for (byte thisNote = 0; thisNote < 20; thisNote++) {
    // to calculate the note duration, take one second divided by the note type.
    //e.g. quarter note = 1000 / 4, eighth note = 1000/8, etc.
    int noteDuration = 1000 / noteDurations[thisNote];
    tone(8, melody[thisNote], noteDuration);
    // to distinguish the notes, set a minimum time between them.
    // the note's duration + 30% seems to work well:
    int pauseBetweenNotes = noteDuration * 1.30;
    delay(pauseBetweenNotes);
    // stop the tone playing:
    noTone(8);
Grumpy_Mike
First error is you are missing a comma after NOTE_D3
Next error is that the variable NOTE_Ab3 has not been declared. So what is this supposed to mean?
Next isthat you have not written a loop function.
Finally that hardware is crap. Never connect a speaker to a pin without any current limiting.
Grumpy_Mike
The tone function can only drive one pin at a time so basically you can't use this function. If you want a two part tune you have to use sound generator software that can produce two or more tones at the same time. This ability is called polyphonic.
I have seen these in the past so I know these are available, search for them.
