Topic: Compatibility of Charger and Battery (Read 179 times) previous topic - next topic
ZebH
Hi all,
I am looking at this battery:
http://www.mindkits.co.nz/lithium-ion-battery-2ah.aspx
And want to charge it with this charger:
https://www.trademe.co.nz/electronics-photography/other-electronics/electronic-components/other/listing-2269192623.htm?rsqid=a9d98961b1e64a3aa27545e9020f82f0-014
However in the description of the battery it says:
Quote
Battery cannot be charged with anything but a specialized Lithium Polymer charger
So what I am wondering is can I charge this battery with the charger I mentioned above?
Thanks very much,
Zeb
One of the most common programming problems is a misplaced/missing bracket.
raschemmel
#1
Aug 12, 2019, 05:42 am Last Edit: Aug 12, 2019, 05:46 am by raschemmel
1A is half of the full current capacity of the battery so you would be charging it at 50%.
Before actually charging a battery I would measure the resistance of the resistor that is shown as the charging current program resistor.
READ page-3 of THIS (look for RPROG
TP4056 DATASHEET
You could start by changing the resistor to 4k (3.9k) to reduce the charging current to 400mA.
If the battery doesn't heat up you can cut the value in half and try again .
If it doesn't heat up you can lower to no less than 1.2k for 1A charging current.
The battery should not heat up. You should not charge it unattended untill you have verified it is not heating up. Allowing it to heat up could result in the battery puffing up which indicates damage.
If can get slightly warm but not hot, without being damaged.
ZebH
