Topic: Neopixel Patterns (Read 230 times) previous topic - next topic
fietstasss
Aug 12, 2019, 03:59 pm Last Edit: Aug 12, 2019, 04:27 pm by fietstasss
Hi all,
I'm looking to make something similar to this:
https://www.youtube.com/watch?v=q2i6Y5AKtBE
Now, I'm struggling with generating the code for the patterns.
I've looked into the default examples of the adafruit libraries, but those are not equal to the patterns in the video below.
Ultimately I'd like to easily call them by (for example):
Code: [Select]
switch (dslrState) {
  case 1:
    RunningLightsPattern();
  case 2:
    CountDownPattern(CDpercentage);  //With the argument being the countdown percentage
  case 3:
    WaitPattern();
  default:
    AllOffPattern();
Most important, as all of this will be 'commanded' from a serial connection to Windows PC, the patterns should all run non-blocking..
I've found the NeoPatterns library seems to work for the non-blocking part (correct me if i'm wrong), but can not get to use it easily.
The library can be found here:
https://github.com/ArminJo/NeoPatterns
How should one start with this?
Thanks in advance!
Grumpy_Mike
Quote
If any example has the delay function call in it, then it is blocking code. The code I saw there was blocking code.
Here is how to write the Adafruit examples as a state machine or non blocking code:-
Code: [Select]
// StrandTest from AdaFruit implemented as a state machine
// pattern change by push button
// By Mike Cook Jan 2016
// Fade function added Sept 2017
#define PINforControl   4 // pin connected to the small NeoPixels strip
#define NUMPIXELS1      64 // number of LEDs on strip
Adafruit_NeoPixel strip = Adafruit_NeoPixel(NUMPIXELS1, PINforControl, NEO_GRB + NEO_KHZ800);
unsigned long patternInterval = 20 ; // time between steps in the pattern
unsigned long lastUpdate = 0 ; // for millis() when last update occurred
unsigned long intervals [] = { 20, 20, 50, 100, 30 } ; // speed for each pattern - add here when adding more cases
int fadeStep = 0; // state variable for fade function
int numberOfCases = 4; // how many case statements or patterns you have
const byte button = 3; // pin to connect button switch to between pin and ground
  strip.begin(); // This initialises the NeoPixel library.
  wipe(); // wipes the LED buffers
  pinMode(button, INPUT_PULLUP); // change pattern button
  static int pattern = 4, lastReading; // start with the fade function
  int reading = digitalRead(button);
  if(lastReading == HIGH && reading == LOW){
    pattern++ ; // change pattern number
    fadeStep = 0; // reset the fade state variable
    if(pattern > numberOfCases) pattern = 0; // wrap round if too big
    patternInterval = intervals[pattern]; // set speed for this pattern
    wipe(); // clear out the buffer
    delay(50); // debounce delay
  lastReading = reading; // save for next time
if(millis() - lastUpdate > patternInterval) updatePattern(pattern);
void  updatePattern(int pat){ // call the pattern currently being created
  switch(pat) {
    case 0:
        rainbow();
    case 1:
        rainbowCycle();
    case 2:
        theaterChaseRainbow();
    case 3:
         colorWipe(strip.Color(255, 0, 0)); // red
    case 4:
         fade(0,255, 0,64, 0,0, 400); // fade from black to orange and back
void fade(int redStartValue, int redEndValue, int greenStartValue, int greenEndValue, int blueStartValue, int blueEndValue, int totalSteps) {
static float redIncrement, greenIncrement, blueIncrement;
static float red, green, blue;
static boolean fadeUp = false;
if (fadeStep == 0){ // first step is to initialise the initial colour and increments
  red = redStartValue;
  green = greenStartValue;
  blue = blueStartValue;
  fadeUp = false;
  redIncrement = (float)(redEndValue - redStartValue) / (float)totalSteps;
  greenIncrement = (float)(greenEndValue - greenStartValue) / (float)totalSteps;
  blueIncrement = (float)(blueEndValue - blueStartValue) / (float)totalSteps;
  fadeStep = 1; // next time the function is called start the fade
else { // all other steps make a new colour and display it
  // make new colour
  red += redIncrement;
  green +=  greenIncrement;
  blue += blueIncrement;
  // set up the pixel buffer
  for (int i = 0; i < strip.numPixels(); i++) {
  strip.setPixelColor(i, strip.Color((int)red,(int)green,(int)blue));
 // now display it
  strip.show();
fadeStep += 1; // go on to next step
if(fadeStep >= totalSteps) { // finished fade
  if(fadeUp){ // finished fade up and back
     fadeStep = 0;
     return; // so next call re-calabrates the increments
  // now fade back
  fadeUp = true;
  redIncrement = -redIncrement;
  greenIncrement = -greenIncrement;
  blueIncrement = -blueIncrement;
  fadeStep = 1; // don't calculate the increments again but start at first change
void rainbow() { // modified from Adafruit example to make it a state machine
  static uint16_t j=0;
    for(int i=0; i<strip.numPixels(); i++) {
      strip.setPixelColor(i, Wheel((i+j) & 255));
    strip.show();
     j++;
  if(j >= 256) j=0;
  lastUpdate = millis(); // time for next change to the display
void rainbowCycle() { // modified from Adafruit example to make it a state machine
    for(int i=0; i< strip.numPixels(); i++) {
      strip.setPixelColor(i, Wheel(((i * 256 / strip.numPixels()) + j) & 255));
    strip.show();
  j++;
  if(j >= 256*5) j=0;
void theaterChaseRainbow() { // modified from Adafruit example to make it a state machine
  static int j=0, q = 0;
  static boolean on = true;
     if(on){
            for (int i=0; i < strip.numPixels(); i=i+3) {
                strip.setPixelColor(i+q, Wheel( (i+j) % 255));    //turn every third pixel on
      else {
               strip.setPixelColor(i+q, 0);        //turn every third pixel off
     on = !on; // toggel pixelse on or off for next time
      strip.show(); // display
      q++; // update the q variable
      if(q >=3 ){ // if it overflows reset it and update the J variable
        q=0;
        j++;
        if(j >= 256) j = 0;
void colorWipe(uint32_t c) { // modified from Adafruit example to make it a state machine
  static int i =0;
    strip.setPixelColor(i, c);
    strip.show();
  i++;
  if(i >= strip.numPixels()){
    i = 0;
    wipe(); // blank out strip
void wipe(){ // clear all LEDs
     for(int i=0;i<strip.numPixels();i++){
       strip.setPixelColor(i, strip.Color(0,0,0));
uint32_t Wheel(byte WheelPos) {
  WheelPos = 255 - WheelPos;
  if(WheelPos < 85) {
    return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
  if(WheelPos < 170) {
    WheelPos -= 85;
    return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
  WheelPos -= 170;
  return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
