Topic: 30rpm d.c geared motor encoder error (Read 383 times) previous topic - next topic
Paul_Dbz1
Recently, I brought a N20 6V 30rpm pololu dc geared motor from here-
https://robu.in/product/n20-6v-30rpm-micro-metal-gear-motor-with-encoder/
And to test the encoder I used the code from this link of the same website.
https://robu.in/run-rotary-encoder-arduino-code/
The issue is, the encoder value just keeps oscillating between 0 & 1 . It neither decreases or increases in response to manually rotating the encoder wheel or programatically rotating the motor.
I have warped around this issue for days now. Am I missing any detail here?
vinceherman
Don't make us go look for your code.  Post it here.  Use code tags.
How do you have the encoder wired up?  Can you draw a picture of your wiring and post it here?
When the encoder is turned, you should be getting changes on 2 of the wires.  It sounds like you only receive changes on one wire.
I would want to confirm that you have both data wires from the encoder connected properly to 2 pins on the arduino.
cattledog
Quote
Run this simple test code while slowly turning the encoder to check your wiring. You should see a repeating sequence like;
11
10
00
01
11
Or the reverse, depending which direction the encoder is turned. You are likely to see repeats of the same value, but the pattern should be clear.
Code: [Select]
#define encoderPinA 2
#define encoderPinB 3
 Serial.begin (115200);
 pinMode(encoderPinA, INPUT_PULLUP);
 pinMode(encoderPinB, INPUT_PULLUP);
 byte a = digitalRead(encoderPinA);
 byte b = digitalRead(encoderPinB);
 if (a == 1)
   Serial.print("1");
   Serial.print("0");
 if (b == 1)
   Serial.print("1");
   Serial.print("0");
TomGeorge
#3
Aug 25, 2019, 03:19 pm Last Edit: Aug 25, 2019, 03:19 pm by TomGeorge
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html .
Thanks.. Tom... :)
Everything runs on smoke, let the smoke out, it stops running....
