Topic: Help me Serial Port for LilyPad USB? (Read 590 times) previous topic - next topic
hungns35
I'm completely new to LilyPad and e-textiles and have previously only used a basic Arduino board.
I purchased a Kookye starting kit for working with LilyPad to get an idea of how it works and if it's something I could use in my science classes. I've put the project together and entered the code correctly, but when I press upload I keep getting the error message: "avrdue: error: programmer did not respond to command: exit bootloader". I was previously getting a message that a port wasn't begin detected, but when I checked under that tab there was only one option for a port.
I think that the port might be my problem (?). I downloaded FTDI, but there are no additional ports appearing in the dropdown menu. Is there something I'm missing to be able to select a different port? The LilyPad blinks when I initially plug it in, but it stops as soon as I start uploading the code.
My operating system is Mojave, version 10.14.
pert
Please do this:
  • (In the Arduino IDE) File > Preferences
  • Uncheck the checkbox next to "Show verbose output during: compilation"
  • Check the checkbox next to "Show verbose output during: upload
  • Click "OK"
  • Sketch > Upload
  • After the upload fails, you'll see a button on the right side of the orange bar "Copy error messages" (or the icon that looks like two pieces of paper at the top right corner of the black console window in the Arduino Web Editor). Click that button.
  • In a forum reply here, click on the reply field.
  • Click the </> button on the forum toolbar. This will add the forum's code tags markup to your reply.
  • Press "Ctrl + V". This will paste the upload output between the code tags.
  • Move the cursor outside of the code tags before you add any additional text to your reply.
meghna31
