Topic: Upload Fail (Read 91 times) previous topic - next topic
kazuki0409
Hi. I have an Arduino UNO, and I'm having a giant problem with uploading.
I was having no problem uploading until about ten minutes ago, and suddenly, well, it started not uploading, so the last program is still running. I don't understand why, so I was hoping you guys could give me some pointers.  ...Oh, and I'm using most of the digital pins and using a Raspberry Pi (which runs on linux ARM, i guess...I'm not so good with electronics) to program.
kazuki0409
by the way, the error says "broken pipe"
ballscrewbob
Clearly that not all it says but you should copy and paste the complete error/s and insert them inside code tags please ( </> )
Might I suggest you also read the posts at the top of the forum and add any much needed details such as the actual OS and the IDE version etc.
Bob.
It may not be the answer you were looking for but its the one I am giving based on either experience, educated guess, google or the fact that you gave nothing to go with in the first place so I used my wonky crystal ball.
kazuki0409
Sorry. It started going normally about 30 minutes later. Are there bugs that only sometimes interfere with arduino?
ballscrewbob
No known real bad or intermittent bugs.
But the release for the Pi can be a bit flakey especially if you just got it from the default repo rather than downloading a know good but up to date copy of the IDE.
A few posts about the topic if you use the search option.
Bob.
