Hello,
I wanted to solder an ON/OFF switch for my arduino. So I bought some switches:
HEREIt works, but there seems to be some power drop since the lcd display which I connected to my arduino will no longer work properly (but connecting it to the battery directly without my soldered switch works). See attached image of my soldered switch.
I assume the poorly made connections between cable and switch is causing this.
Are there some kind of adapters which I can use to connect pin cables with power jacks/switches etc?
