Topic: Help with AD5669 I2C DAC module (Read 134 times) previous topic - next topic
ejfernandes
Hi everyone,
Did someone ever worked with a similar module? If so can you post here the code ? I'm having problems understanding how to work with more than one ports simultaneously and i would like to understand how it operates.
If someone could help me i would really appreciate it.
Best regards
GolamMostafa
Give a link to its pdf version of data sheets.
ejfernandes
https://media.ncd.io/sites/2/20170721134850/AD5629R_5669R.pdf
Any help would be appreciated.
GolamMostafa
#3
Aug 20, 2019, 03:17 pm Last Edit: Aug 20, 2019, 03:38 pm by GolamMostafa
1.  This is an untested proposed connection diagram between the AD5669-R3 and Arduino UNO using I2C Bus.
2.  Connect a DVM between VOUTA-pin and GND.
3.  Upload the following sketch into UNO. Check that the DVM reads about 1.70V.
Code: [Select]
#include<Wire.h>     //this file is needed for the I2C Bus operation
   Serial.begin(9600);        //enable serial interface with PC
   Wire.begin();                 //create I2C Bus
   //----check that the device is present at address ob1010111
   Wire.beginTransmission(0b1010111);
   byte busStatus = Wire.endTransmission();
   if(bustatus != 0)
      Serial.print("Device is not found...!");
      while(1);     //wait for ever
   //---set internal reference voltage for DAC-A
   Wire.write(0b10000000);
   Wire.write(0b00000000);
   //--- write 0x570A into the device to get 1.70V at VOUTA pin
   Wire.write(0x57);
   Wire.write(0x0A);
   //--update DAC A Register-------
   Wire.write(0b00000001);
Please, report the result.
