Topic: Optical encoder; direction determining problem (Read 129 times) previous topic - next topic
Stronghold_
Hello everyone,
I have 2 Optical encoders in a row, and I can read all the pulses passed by these encoders. (Basically, wheel rotating, and I should read the pulses ) I use interrupt for both encoders.
The question is that is it possible to determine the direction of the wheel in the interrupt itself?
If yes, I will be appreciated if you suggest how;
I can not do it in the loop because there is a lot of delays in it.
This is my code;
Code: [Select]
int pin = 2;
int pin2 = 3;
int dovrSayi = 0;
int counter = 0;
int dovrSayi2 = 0;
int counter2 = 0;
unsigned long vaxt = 0 ;
unsigned long vaxt2 = 0;
int signals = 15; // pulses that needed for one rotation
int bir = 0 ;
unsigned long currentTime = 0;
  // Set encoder pins as inputs
  pinMode (pin, INPUT);
  pinMode(pin2, INPUT);
  Serial.begin (9600);
  attachInterrupt(digitalPinToInterrupt(pin), updateCounter, RISING);
  attachInterrupt(digitalPinToInterrupt(pin2), updateCounter2, RISING);
  Serial.print ("counter : ");
  Serial.println(counter);
  Serial.print ("dovr sayi : ");
  Serial.println(dovrSayi);
   if ((vaxt2 > vaxt) ) {
    Serial.println(vaxt2 - vaxt);
  if (!(vaxt2 > vaxt) ) {
    Serial.println(vaxt - vaxt2);
  delay(300);
  if (counter >= signals) {
    dovrSayi ++;
    counter = 0 ;
  if (counter2 >= signals) {
    dovrSayi2 ++;
    counter2 = 0 ;
// Serial Read and other stuf also added;
void updateCounter()
  counter ++;
vaxt = millis();
void updateCounter2()
  counter2++;
  vaxt2 = millis();
Paul_KD7HB
All depends on HOW you have the encoders positioned!!!!! When one is seeing the LED light through a hole or slot, the other MUST be off. Do you have them mounted this way?
Paul
jremington
#2
Aug 21, 2019, 01:54 am Last Edit: Aug 21, 2019, 01:56 am by jremington
This introduction should answer your questions: http://www.creative-robotics.com/quadrature-intro
Stronghold_
Thank you very much  !!
The link really helped me to solve the problem...
