Topic: erreur du code  (Read 133 times) previous topic - next topic
moi4000
Aug 20, 2019, 06:35 pm Last Edit: Aug 20, 2019, 07:02 pm by moi4000
salut
je voudrai savoir pourquoi cela ne marche pas c'est un multimètre j ai ce message d erreur
Arduino : 1.8.5 (Windows 10), Carte : "Arduino/Genuino Uno"
sketch_aug20b:20: error: redefinition of 'float Vacross'
float Vacross,Iamp = 0;
C:\Users\AppData\Local\Temp\arduino_modified_sketch_744390\sketch_aug20b.ino:1:7: note: 'float Vacross' previously declared here
sketch_aug20b:20: error: redefinition of 'float Iamp'
C:\Users\AppData\Local\Temp\arduino_modified_sketch_744390\sketch_aug20b.ino:1:15: note: 'float Iamp' previously defined here
sketch_aug20b:21: error: redefinition of 'const int Shunt_Res'
const int Shunt_Res = 1000;
C:\Users\AppData\Local\Temp\arduino_modified_sketch_744390\sketch_aug20b.ino:2:11: note: 'const int Shunt_Res' previously defined here
C:\Users\AppData\Local\Temp\arduino_modified_sketch_744390\sketch_aug20b.ino: In function 'void setup()':
sketch_aug20b:24: error: redefinition of 'void setup()'
C:\Users\AppData\Local\Temp\arduino_modified_sketch_744390\sketch_aug20b.ino:4:6: note: 'void setup()' previously defined here
C:\Users\AppData\Local\Temp\arduino_modified_sketch_744390\sketch_aug20b.ino: In function 'void loop()':
sketch_aug20b:28: error: redefinition of 'void loop()'
C:\Users\AppData\Local\Temp\arduino_modified_sketch_744390\sketch_aug20b.ino:8:6: note: 'void loop()' previously defined here
exit status 1
Ce rapport pourrait être plus détaillé avec
l'option "Afficher les résultats détaillés de la compilation"
activée dans Fichier -> Préférences.
le code
Code: [Select]
 Vacross = analogRead(A0);
 Vacross = (Vacross * 5.0) / 1023.0;
 Iamp = (Vacross * 1000) / Shunt_Res;
 Serial.print("Current = ");
 Serial.print(Iamp);
 Serial.println("mA");
#include <LiquidCrystal.h>
float Vacross,Iamp = 0;           <--------------------erreur ici
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
 lcd.begin(16, 2);
 lcd.setCursor(8, 0);
 lcd.print("Current = ");
 lcd.print(Iamp);
 lcd.print("mA");
merci d avance
J4l13n
#1
Aug 20, 2019, 06:40 pm Last Edit: Aug 20, 2019, 06:52 pm by J4l13n
Salut, mets tes codes entres des balises
https://forum.arduino.cc/index.php?topic=315372.0
while(success!=found){
   try++;
   if(fail){
        tryAgain();
moi4000
ton lien ne marche pas
dfgh
moi4000
#4
Aug 20, 2019, 06:59 pm Last Edit: Aug 20, 2019, 07:03 pm by moi4000
a oui mais j ai pas la barre avec les smiler etc... j ai juste écrit
"With Quick-Reply you can write a post when viewing a topic without loading a new page. You can still use bulletin board code and smileys as you would in a normal post."
edit
c'est bon j ai réussi dsl
dbrion06
Vous avez certainement begayé (accident de copié collé??)  liors de l'ecriture de votre programme:
il a au mois deux declarations de vaCross, de setup()...
Comment voulez vous que le compilateur se debrouille (il est très bête, quoique performant).
en passant:
Serial.begin(9600); est utilisé (et copié collé) systematiquement.
En fait, tous les terminaux serie sont beaucoup plus rapides, et vous pouvez mettre sans crainte
Mais UNE SEULE FOIS....
lesept
Tu as plusieurs fois le setup et la loop dans ton code. Pour corriger c'est simple :
Déplace les Serial.print après les lcd.print et ensuite enlève toutes les lignes avant le #include
A force d'essayer on finit par réussir... Donc, plus ça rate, plus on a de chances que ça marche (proverbe Sharduinok).
