Topic: Of Millis, Fade and Stay ON or Off (Read 200 times) previous topic - next topic
Polliwog
Hello Everyone.  I am new here and new to Arduino programming.  I am experimenting with millis() to better understand it.  I found a sketch at The Bald Engineer to fade an LED up and then down. I think I understand this pretty much.  I also read over the Tute here.
 I thought I might try altering the code so the led will fade in, then stay on a few seconds, then turn off. However, now I get nothing.  Could someone please take a look at the this code and tell me where I am going wrong.
Code: [Select]
#define UP 0
#define DOWN 1
const int minPWM = 0;
const int maxPWM = 255;
byte fadeDirection = UP;
int fadeValue = 0;
byte fadeIncrement = 5;
unsigned long previousFadeMillis;
unsigned long previousMillis;
int fadeInterval = 50;
int onInterval = 3000;
  analogWrite(pwmLED, fadeValue);
void doTheFade(unsigned long thisMillis) {
     if (thisMillis - previousFadeMillis >= fadeInterval) {
     if (fadeDirection == UP) {
         fadeValue = fadeValue + fadeIncrement;
     if (fadeValue >= maxPWM) {
          fadeValue = maxPWM;
      if (pwmLED, maxPWM)  {
 }      analogWrite(pwmLED, HIGH);
      if (thisMillis - previousMillis >= onInterval) {
 }     analogWrite(pwmLED, LOW);
    previousMillis = thisMillis;
    previousFadeMillis = thisMillis;
                                                          // get the current time, for this time around loop
  unsigned long currentMillis = millis();                    // all millis() timer checks will use this time stamp
  doTheFade(currentMillis);
larryd
Use CTRL T ( or CMD T )  to format your code.
What is this ?
if (pwmLED, maxPWM)
No technical PMs.
If you are asked a question, please respond with an answer.
If you are asked for more information, please supply it.
If you need clarification, ask for help.
Delta_G
#2
Aug 21, 2019, 04:21 am Last Edit: Aug 21, 2019, 04:22 am by Delta_G
You've got braces all over the place in the doTheFade function.  Press control-T in the IDE to autoformat it and line up the blocks and you should be able to see where your logic wen't wrong.
Code: [Select]
if (pwmLED, maxPWM)
What's the comma doing?  Did you mean ==?
(Ninja posted by @larryd  at least we agree)
|| | ||| | || | ||  ~Woodstock
Please do not PM with technical questions or comments.  Keep Arduino stuff out on the boards where it belongs.
Polliwog
Thanks
That was a mistake.  I changed it to;   if (pwmLED  == maxPWM)   However, I am still getting nothing on the LED.
Delta_G
Thanks
Yeah, you still got braces all over the place.  It matters where you put those.
|| | ||| | || | ||  ~Woodstock
Polliwog
Well guys,  still not working.  Here is the corrected code.  Still does nothing.
Code: [Select]
// Example Fading LED with analogWrite and millis()
// See baldengineer.com/fading-led-analogwrite-millis-example.html for more information
// Created by James Lewis
#define UP 0
#define DOWN 1
int pwmLED = 5;
int fadeValue = 0;
         fadeValue = maxPWM;
    if (pwmLED == maxPWM)  {
larryd
#6
Aug 22, 2019, 01:28 am Last Edit: Aug 22, 2019, 01:29 am by larryd
Hint
int pwmLED = 5;
No technical PMs.
Delta_G
So 5 can't equal 255?  Seems like we've already talked about that in this thread.
|| | ||| | || | ||  ~Woodstock
Polliwog
Thank you.  A little help sometimes is all is needed
Polliwog
Well,  I did all the corrections suggestions, still see nothing but a dimly lit LED haunting me.  Thanks for all your help.  It back t the tutorial boards for me.
larryd
Show us your latest incarnation.
No technical PMs.
Polliwog
Here it is
Code: [Select]
#define UP 0
#define DOWN 1
int pwmLED = 3;
int fadeValue = 0;
unsigned long thisMillis2;
         fadeValue = maxPWM;
       if (fadeValue == maxPWM) {
    if (pwmLED == HIGH)  {
  previousMillis = thisMillis2;
larryd
You have:
int pwmLED = 3;
You then you have:
if (pwmLED == HIGH)
You essentially have:
if (pwmLED == HIGH)  or with numbers  if (3 == HIGH)
Stop, and read the above over and over until you understand the problem ;) .
No technical PMs.
TheMemberFormerlyKnownAsAWOL
#13
Aug 22, 2019, 07:04 pm Last Edit: Aug 24, 2019, 08:19 pm by TheMemberFormerlyKnownAsAWOL
Code: [Select]
That's not very bright.
(Pun intended)
Polliwog
Hey guys.
My original idea was to fade in a red LED, then hold it high for a for a while.  After it has been high for a bit , then fade in a yellow to make orange.  Then fade out the red to make yellow only for a time.  Then continue with green and blue to simulate a rainbow. To me, it's quite daunting, after learning how to fade without delay.
Thing is, I am getting really frustrated now so I think the best thing is to leave it and go on to some other projects for a while.
Thanks everyone.
