Topic: Can the voltage on a mega or uno be adjusted at 5v or 3.3v pin? (Read 336 times) previous topic - next topic
GoForSmoke
the amps arnt high enough for what id need, would need a external power supply n was hoping might power a vape atomizer.
Do you know the term 'thermal mass'? It has thermal inertia, anything that you would heat up has this.
So you can use PWM to deliver ~500 pulses every second. The length of the pulses makes a smooth average as the pulse is a tiny push against the thermal mass inertia. Uno has ~1000/sec PWM on, IIRC 2 pins.
Even at full power, how much heat gets delivered in one or two milliseconds? A 50% pulse looks the same as half of 100% (no pulse, just ON the whole time). Thermal inertia will smooth the heating out, a physical mass filter.
You read the pot with an analog pin to get the pulse percent to use. A tiny trim pot could be used since it won't be carrying a current load to speak of.
1) http://gammon.com.au/blink  <-- tasking Arduino 1-2-3
2) http://gammon.com.au/serial <-- techniques howto
3) http://gammon.com.au/interrupts
Your sketch can sense ongoing process events in time.
Your sketch can make events to control it over time.
johnwasser
Code: [Select]
 analogReference(EXTERNAL);
  int sensorValue = analogRead(0);
  float voltage= sensorValue * (5.0 / 1023.0);
Unless the Aref (EXTERNAL reference) pin is 5.0V your 'voltage' calculation is wrong.  Replace the '5.0' value with the actual analog reference voltage.
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
septillion
And now that you are there anyway, change the 1023 to the correct 1024 :)
Use fricking code tags!!!!
I want x => I would like x, I need help => I would like help, Need fast => Go and pay someone to do the job...
NEW Library to make fading leds a piece of cake
https://github.com/septillion-git/FadeLed
GoForSmoke
You do know that the difference between /1023 and /1024 is less than the accuracy of the ADC, by about half?
I get my chuckles when the difference argued over isn't really there.
septillion
Yeah, but why introduce extra error? And extra calculations. Division by 1024 is a lot easier to handle :)
GoForSmoke
There was a long thread about this a few years ago.
Yeah, there are times when /1023 makes more sense to reasonable un-fixated people.
