Topic: expected primary-expression before ">" token (Read 132 times) previous topic - next topic
EminB
When I try to check my code I get that error please help me .
Code: [Select]
#define echoPin 7
#define trigPin 4
#define red 8
#define green 11
int maximumRange = 50;
int minimumRange = 0;
  pinMode(trigPin, OUTPUT);
  pinMode(echoPin, INPUT);
  pinMode(green, OUTPUT);
   pinMode(red, OUTPUT);
int mesafe(int maxrange, int minrange)
  long duration, distance;
  digitalWrite(trigPin,LOW);
  delayMicroseconds(2);
  digitalWrite(trigPin, HIGH);
  delayMicroseconds(10);
  digitalWrite(trigPin, LOW);
  duration = pulseIn(echoPin, HIGH);
  distance = (duration/2) / 29.1;
  delay(50);
  if(distance <= 70  || distance => 40 )    [b]// THATS THE ERROR LINE [/b]
  digitalWrite(red, HIGH)
  else{
digitalWrite(red, LOW)
if(distance <= 40  || distance => 10)
digitalWrite(green, HIGH)
else{
digitalWrite(green, LOW)
CrossRoads
You have => vs >=
Also missing some ;s
and { } with the if () statements
Code: [Select]
#define echoPin 7
#define trigPin 4
#define red 8
#define green 11
  distance = (duration / 2) / 29.1;
  delay(50);
  if  (distance <= 70  || distance >= 40 ) {  // THATS THE ERROR LINE
    digitalWrite(red, HIGH);
  else {
    digitalWrite(red, LOW);
  if (distance <= 40  || distance >= 10) {
    digitalWrite(green, HIGH);
  else {
    digitalWrite(green, LOW);
EminB
I remade my code :::::
#define echoPin 7
#define trigPin 4
#define red 8
#define green 11
 Serial.begin (9600);
  distance = (duration/2) /29.1;
  if  (distance <= 70   ) {
  else {
  if (distance <= 40  ) {
  else {
but I want to do that  :::          red led active when distance between 70 and 40
                                              green led active when distance between 40 and 5
How can I do that  ?
slipstick
You to be able to say AND, written as && e.g.
if (distance >=5 && distance <= 40) {set green on} etc
Steve
EminB
thanks but I see tht like if ( distance <=70 || distance >= 40)
It didnt give any syntax error but It doesn't worked . Do you know thats why ?
sterretje
#5
Aug 23, 2019, 08:00 am Last Edit: Aug 23, 2019, 08:02 am by sterretje
That condition will always be true; distance 0 .. 70 or distance 40 .. inf
PS. This is not an Installation and troubleshooting question; I will ask a moderator to move it.
If you understand an example, use it.
If you don't understand an example, don't use it.
Electronics engineer by trade, software engineer by profession. Trying to get back into electronics after 15 years absence.
slipstick
Because when I said AND && I didn't mean OR ||. The distance is always less than 70 OR greater than 40. But it's not always greater than 40 AND less than 70.
Steve
