Topic: I have some problems with my Xbee communication (Read 54 times) previous topic - next topic
2nebin
I want these 2 Xbee modules communicate with each other continuously.
However, with my codes, they communicate just 2 or 3 times and stop. I really don't know what is the problem.
Please give me some help...
These are my codes (Actually they are exactly same except for their "ID" and "initial value").
I'm a totally novice C language programmer so my codes may look dirty. Sorry about that...
**Code A**
Code: [Select]
#define Xbee_ID "10"
    char initial_val[] = "100";  /*Value has to be less than 4 digits*/
    int other_ID[10] = {0, };
    int data[10] = {0, };
    int number_of_ID = 1;
    bool checker(int array_input[], int number);
    int reproduce_data(int data[], int number);
    void trans_till_get(int value, int ID);
      /*Start Serial communication and set initial value*/
      other_ID[0] = atoi(Xbee_ID);
      data[0] = atol(initial_val);
      trans_till_get(data[0], other_ID[0]);
    /*Design of transmitting data : ID(2 digits) is attached behind the float data(4 digits)
     * ex) 5164/97
     *     data/ID
      if (Serial.available()){
        /****Data receiving part****/
        String answer = Serial.readStringUntil('\r');
        if (answer.length() > 6) return;  // Filtering false data
        char c_answer[6] = {0, };
        answer.toCharArray(c_answer, answer.length()+1);  /*Making input data char array*/
        long i_answer = atol(c_answer);  /*Reading data and making it long integer*/
        int ID = i_answer % 100;   /*Identify ID*/
        i_answer = i_answer /100;   /*Removing ID*/
         /* Identifying ID or Append new ID if it doesn't exist*/
        for (int i=0; i < sizeof(other_ID)/sizeof(int); i++){
          if(ID == other_ID[i]){
            data[i] = i_answer; /*Saving data in data[]*/
          else if(!other_ID[i]) {
            other_ID[i] = ID; /*Append new ID*/
            number_of_ID = i+1; /*Saving number of ID*/
        /****Data checking part****/
        if (checker(data, number_of_ID))
          trans_till_get(reproduce_data(data, number_of_ID), other_ID[0]);  /*Transmit data if it's checked okay*/
        Serial.flush();
    bool checker(int array_input[], int number){ /*Return 0 if one of contents of input_array[] is 0*/
     for (int i=0; i < number; i++){
        if (array_input[i] == 0)  return false;    }
      return true;
    int reproduce_data (int input_data[], int number){ /*Prototype: sum it all*/
      int result = 0;
      /****Data reproducing part****/
      for (int i=0; i<number; i++){
        result += input_data[i];
      /*Initializing data set*/
      for(int j=0; j<10; j++) input_data[j] = 0;
      input_data[0] = result;
      return result;
    void trans_till_get(int value, int ID){
      /*Transmitting data*/
      Serial.print(String(value) + String(ID));
      Serial.print('\r');
      return;
**Code B**
Code: [Select]
    #define Xbee_ID "20"
    char initial_val[] = "200";  /*Value has to be less than 4 digits*/
     * ex) 5164/97
     *     data/ID
        Serial.flush();
        if (array_input[i] == 0)  {
          return false;
      return true;
      int result = 0;
      return result;
      Serial.print('\r');
      return;
As you can see in attached results, program quit in the middle of the process.
**Expected result**
[COM5]
10010
40010
110010
290010
660010
. (go on)
[COM18]
20020
30020
70020
180020
370020
1030020(an error might occur but not that important now)
. (go on)
**However...**
[COM5]
10010
40010
110010
290010 (quit)
[COM18]
20020
30020
70020
180020 (quit)
I'm guessing it's a problem related to buffer but I'm not sure about this.
What would be a problem?
