Topic: Somewhat strange way of programming observed in arduino avr core (Read 462 times) previous topic - next topic
liuzengqiang
Been digging into USB stuff for a few days. I keep seeing some strange things like #define and magic numbers coexist. This following one is a new discovery. Hope someone can justify its existence.:
USBCore.cpp in arduino's avr core folder:
//Line 45 in IDE 1.8.4
#ifndef USB_PRODUCT
// If no product is provided, use USB IO Board
#define USB_PRODUCT     "USB IO Board"
#endif
const u8 STRING_PRODUCT[] PROGMEM = USB_PRODUCT;
So we know USB_PRODUCT is a def and STRING_PRODUCT is a PROGMEM C-string defined by STRING_PRODUCT, only residing in PROGMEM.
// Line 524 in IDE 1.8.4
return USB_SendStringDescriptor(STRING_PRODUCT, strlen(USB_PRODUCT), TRANSFER_PGM);
Since we know STRING_PRODUCT is a PROGMEM C-string, we CAN'T use strlen() on it. We must find its length to make the call! Since USB_PRODUCT is a def, we CAN use strlen on it, or rather, on the string literal created by its def.
Instead of using the proper strlen_P(), a literal string was defined and used once (yes, discarded from stack, I get it), just so that the developer CAN call strlen() on it. What a load of non-sense or am I missing something?
Juraj
strlen(USB_PRODUCT) is evaluated by the compiler, not in runtime
liuzengqiang
Any reference to this claim? I'd like to confirm it if possible. This means it costs no time to do this, which seems a good reason. I thought this instantiates an unnamed string literal and then call strlen() to return its length. Thanks.
Juraj
it works :-)
Juraj
Arduino has compiler option -Os
    Optimize for size. -Os enables all -O2 optimizations except those that often increase code size:
-O2 includes -foptimize-strlen
https://gcc.gnu.org/onlinedocs/gcc/Optimize-Options.html
liuzengqiang
Figured out a simple test:
  int a=25;
Compilation:
Sketch uses 450 bytes (1%) of program storage space. Maximum is 32,256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2,039 bytes for local variables. Maximum is 2,048 bytes.
const char str25[]="0123456789012345678901234";
  int a=strlen(str25);
Compilation:
So there is no difference. Thus this means you are perfectly right Sir/Mam! Thank you!
Juraj
https://en.wikipedia.org/wiki/Juraj
liuzengqiang
