Topic: bitWrite, bitSet and bitClear to alter bytes in an array (Read 79 times) previous topic - next topic
Moshtaraq
Hi again,
I'm trying to make a snake game but running into some problems.
(There are probably better ways to make a snake game but I don't want to copy someone elses script, I try to learn and run into problems so I can solve them and progress)
My intent:
I have an array of 8 bytes called 'field' and an array with the coordinates of the body of the snake called 'tail' e.g.:
x: 1,1,1
y: 1,2,3
tail[]={{1,1,1},{1,2,3}}
I expect the following to happen:
take the coordinates and set those bits in the field(later they become dots on a led matrix)
so for the coordinates above it would look like:
11100000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
And I wrote a function to do that called update_field(), in this function I use bitWrite to set the bit on those coordinates but the updated field returns empty.
Code: [Select]
byte field[8] = {
  B10000000,
  B00000000,
  B00000000,
  B00000000,
  B00000000,
  B00000000,
  B00000000,
  B00000000,
int const snake_length = 3;
int tail[2][snake_length] = {
  {1, 2, 3},
  {2, 4, 6}}; //1 indexed coordinates
int x = 0;
int y = 0;
void update_field() {
  for (int i = 0; i < 8; i++) {//clears the whole field
    field[i] = B00000000;
  for (int i = 0; i < snake_length; i++) {
    x = tail[1][i] - 1; //reads coordinate
    y = tail[2][i] - 1; //0 indexed array
    bitWrite(field[x], y,HIGH);//sets bit nr. y of row nr. x to 1
    Serial.print("row for x = ");
    Serial.println(x);
    Serial.println(field[x]);
  update_field();
  Serial.println("updated field : ");
    for (int j = 0; j < 8; j++) {
      Serial.print(bitRead(field[i], j));
    Serial.print('\n');
my serial print output looks like:
Code: [Select]
row for x = 1
0
row for x = 3
0
row for x = 5
0
updated field :
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
since the script compiles and uploads I assume the function bitWrite is used correctly? (I also tried bitSet but same result)
Thanks in advance.
pert
Code: [Select]
  {1, 2, 3},
Code: [Select]
You forgot that the first dimension of the array is zero indexed. There is no tail[2], so you're reading some random memory and then writing HIGH to that bit position.
Moshtaraq
And I thought I was being carefull with the indexing  ::)
Thanks! Works fine now.
pert
You're welcome. I'm glad to hear it's working now. Enjoy!
Per
