Topic: Problem with Reset (Read 250 times) previous topic - next topic
Filnet
Hello
I have some problems with RESET.
I want to use Watchdog librairies (compatible MKR) The sketch go well but the reset is not effective and sleep the MKR.
I try to connect pin RESET with GND, result is the same : program is stop but no reset.
Could you help me.
Thanks
NB : when I push RST button (once), it never reset.
Filnet
Somebody can help me?
For instance, when I use Adafruit Watchdog Library Demo :
Here is the monitor loging:
Adafruit Watchdog Library Demo!
Enabled the watchdog with max countdown of 4000 milliseconds!
Looping ten times while resetting the watchdog...
Loop #1
Loop #2
Loop #3
Loop #4
Loop #5
Loop #6
Loop #7
Loop #8
Loop #9
Loop #10
Get ready, the watchdog will reset in 4000 milliseconds!
And no reset, the MKR GSM seems freeze.
I need to upload the sketch for another attempt (Reset button is inefficient)
thinkbetter
Filnet
Thanks for your response.
// Adafruit Watchdog Library Basic Usage Example
// Simple example of how to use the watchdog library.
// Author: Tony DiCola
#include <Adafruit_SleepyDog.h>
  //while(!Serial); // wait for Arduino Serial Monitor (native USB boards)
  Serial.println("Adafruit Watchdog Library Demo!");
  int countdownMS = Watchdog.enable(4000);
  Serial.print("Enabled the watchdog with max countdown of ");
  Serial.print(countdownMS, DEC);
  Serial.println(" milliseconds!");
  Serial.println("Looping ten times while resetting the watchdog...");
  for(int i = 1; i <= 10; ++i) {
    Serial.print("Loop #"); Serial.println(i, DEC);
    Watchdog.reset();
  Watchdog.disable();
  Serial.print("Get ready, the watchdog will reset in ");
  delay(countdownMS+1000);
  Serial.println("You shouldn't see this message.");
  NVIC_SystemReset();
