Topic: Seeed Studio tft Touchscreen (Read 222 times) previous topic - next topic
Gizmobizmo8
I'm having trouble with my 2.8 V2 tft touchscreen.  I posted something previously about it, but I guess it was taken down.  I've used a source code a vendor gave me, that was included in the arduino library, but it isn't working.  Could someone please assist me with a suggestion?   :)
void setup () {
#include <Adafruit_GFX.h>
#include <Adafruit_SPITFT.h>
#include <Adafruit_SPITFT_Macros.h>
#include <gfxfont.h>
#include <Adafruit_ILI9341.h>
Error code ----> exit status 1
Error  compiling for board Arduino/Genuino Mega or Mega 2560
david_prentice
#1
Aug 25, 2019, 05:30 pm Last Edit: Aug 25, 2019, 05:31 pm by david_prentice
Post a link to the display that you have bought.
Install / Upgrade Adafruit_ILI9341 and Adafruit_GFX via the IDE Library Manager.
Then run all the Adafruit_ILI9341 library examples.
If you have a problem,  quote library version and example name.
Don't post the whole code.   (we can find it in our library examples)
Just paste any changes you have made e.g. constructor statement to match your display shield wiring.
There is no point in trying to write your own sketch until you have run all the library examples.
David.
Gizmobizmo8
David.
Okay, thank you sir.  I have tried the Adafruit libraries the guy at the shop sent me.  He said there's a code they used, but he has to find it.  I'm  using a Seeed studio tft, but I can't get the codes to cooperate.  I'll paste the link for the product for you.
david_prentice
Don't ever trust the guy in the shop unless you know him personally.
Only use libraries "approved" by the IDE Library Manager.
We can get you working with Adafruit_ILI9341.
Once you have it working with Adafruit_ILI9341 we can try with other libraries.
Note that the Seeed library is non-standard.
You will find Adafruit libraries easier to use e.g. running popular sketches available on the Internet.
David.
Gizmobizmo8
David.
Alright, thank you sir.  Here's a description to the link:  http://wiki.seeedstudio.com/2.8inch_TFT_Touch_Shield_v2.0/.  I'll keep trying with that Adafruit _ILI9341.
Gizmobizmo8
Okay, I'm getting an error message that says,  avrdude: can't open device "giveio"
avrdude:  failed to open parallel port "lptl".
This is version 1.0.0.11.
david_prentice
1. Install / Update the Arduino IDE.   Currently v1.8.9
2. Run a few examples e.g. Blink, Asciitable
3. Install / Upgrade Adafruit_ILI9341 and Adafruit_GFX via the IDE Library Manager.
4. Run Adafruit_ILI9341 examples
e.g. from Adafruit_ILI9341/examples/graphicstest/graphicstest.ino
// Use hardware SPI (on Uno, #13, #12, #11) and the above for CS/DC
Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS, TFT_DC);
// If using the breakout, change pins as desired
//Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS, TFT_DC, TFT_MOSI, TFT_CLK, TFT_RST, TFT_MISO);
Replace the constructor with:
Adafruit_ILI9341 tft = Adafruit_ILI9341(5, 6, 7);
I always enable verbose Compile in IDE:  File->Preferences
Using library SPI at version 1.0 in folder: C:\Program Files (x86)\Arduino-1.8.9\hardware\arduino\avr\libraries\SPI
Using library Adafruit_ILI9341 at version 1.5.1 in folder: C:\Users\David Prentice\Documents\Arduino\libraries\Adafruit_ILI9341
Using library Adafruit_GFX_Library at version 1.5.6 in folder: C:\Users\David Prentice\Documents\Arduino\libraries\Adafruit_GFX_Library
You should see something similar.
David.
pert
Do you mean this?:
https://forum.arduino.cc/index.php?topic=632774
I just checked and no topic you posted has ever been taken down.
Here's how you can find your previous posts:
  • Hover the mouse pointer over your avatar in the top right corner of any arduino.cc page.
  • Click "Profile".
  • Click "Forum Settings > Edit".
  • Click "Show Posts".
This indicates you are doing a Sketch > Upload Using Programmer with Tools > Programmer > Parallel Programmer selected. Shortcuts for Upload Using Programmer are Ctrl + Shift + U or holding the Shift key while clicking the Upload button.
Are you intentionally trying to do an Upload Using Programmer? If so, do you really have a parallel port programmer (if so, you're probably the only Arduino user to use one this decade).
Gizmobizmo8
Do you mean this?:
  • Click "Profile".
Thanks for the feedback.  Yeah, that parallel port sounds strange, lol.  Still trying to get use to all of this programming talk, lol.
Gizmobizmo8
Yeah, I tried to do this step by step, and my Arduino Mega wasn't showing on the ports.  So I googled how to update it, and it said to uninstall, then reinstall, then restart the computer.  I'm  having trouble reinstalling now,  so I'll have to wait to try to run that code again.  When I tried it, it didn't work, and I have the latest version already.
david_prentice
#10
Aug 26, 2019, 02:00 pm Last Edit: Aug 26, 2019, 02:01 pm by david_prentice
This should delete any previous installation.   And install the new version.
You don't need to restart the PC.  Or do anything yourself.
If you have already got v1.8.9 you can install v1.8.8 (to replace v1.8.9).
Then install v1.8.9 (to replace v1.8.8 )
It is very important to learn how to find an example e.g. File->Examples
And how to select the correct Board e.g. Tools->Board->Mega2560
And select the correct COM port e.g. Tools->Port
And how to build and run a sketch e.g. click the "right-arrow" icon below the Edit tab.
Or how to view the Serial Terminal.  e.g. click right-hand icon
I am sure that there are many Internet videos.
Take notes on paper as you make each step.
Then you can describe exactly what you have done.   And where any problems arise.
It may sound onerous.   Pencil and paper are cheap.   Numbered steps make it easy for you (or your readers) to replicate your checklist.
Gaining experience with the Arduino IDE requires no programming knowledge.
You navigate around menus and examples.
At most,  you may have to edit a constructor statement to match your hardware.
David.
Gizmobizmo8
I just got an email from the manufacturer.  They just redirected me to the products page with the library.  I'll just try that again, once I reinstall the Com ports, and LPT.
david_prentice
If your PC is less than 15 years old it has only got USB ports.
You just need one USB port for your Mega2560.
Do not try and install LPT or even RS232 unless you have a very old PC.
In which case it would already have DB9 RS232 ports and DB25 LPT ports.
Are you using Windows10 or Win7 ?
Does your PC have USB sockets ?
Yes,  of course the Seeed libraries should work.
But you need to get basic Arduino experience established first.
Any attempt to install LPT on a Win7 or Win10 PC will probably kill the PC.
David.
Gizmobizmo8
#13
Aug 26, 2019, 06:47 pm Last Edit: Aug 27, 2019, 05:37 am by Gizmobizmo8
David.
Yeah, I have 10.  Thanks so much for your guidance sir.  I'll be sure to troubleshoot when I get off work.
