Topic: Long range sx1268 wireless module DRF1268DS with Arduino UNO for home automation (Read 3340 times) previous topic - next topic
srnet
The SW pin is connected to the /CTRL(or VDD) pin of RF switch PE4259. In normal operation, it should be connected to VCC but in sleep mode, it should be connnected to GND in order to reduce the static current. Therefore you can use a I/O pin to control it.
Are you absolutly sure about that ?
The data sheet for the DRF1268F seems very clear;
DIO2 controls the /CTRL pin of RF switch PE4259.
and
The SW pin is connected to the VDD pin of RF switch PE4259.
Seems to me that you need to use both SW and DIO2 for controlling the DRF1268F, DIO2 when switching between RX and TX and SW when you want to put the device to sleep.
I am aware thet you would normally use the SetDIO2AsRfSwitchCtrl option to control DIO2 automatically.
http://www.50dollarsat.info/
http://www.loratracker.uk/
dorji_com
and
Thanks for the update. The DIO2 pin is used to switch RX and TX of sx1262 when the SW is connected to VCC. If you want to minimize the sleep current (<1uA) of DRF1268T, the PE4259 should be shut up totally by setting SW and DIO2 pins to GND.
dorji_com
Hello,
 I am also interested in testing the 868 MHz version.
 Thanks.
Thank you. We will send you the tracking number by PM very soon.
Oldtron
In the original post I notice that the DRF1262DS is connected directly to a Arduino UNO.
The UNO digital pins are 5v. But in the DRF1262DS data sheet it states that:
Rx 3.3v
Tx 3.3v
Mo grd or 3.3v
Wonder which I should believe ?
dorji_com
Rx 3.3v
Tx 3.3v
Mo grd or 3.3v
Thanks for your update. The logic level of DRF1262DS is 3.3V so it will be better to connect it to 3.3V I/O pins. Anyway we add serial resistor on the I/O pins of the modules to restrict the current so these pins can be connected to 5V pins of UNO.
Oldtron
Thank you very much for the clarification.
I will continue with the testing.
kayel
I received my modules today. Thanks.
MO and AU are inverted. Which one is right? I suppose it doesn't matter if I use the DAD07?
dorji_com
Hello Kevin, It should be the mistake of the layout engineer. The silkscreen of MO and AU on the module should be swapped. We will correct it in next version. The pin sequence and pin names in the datasheet and on the testing board DAD07 are correct. Therefore you can solder it directly on the DAD07 without problem. It's really sorry for the inconvenience.
kayel
 Hello testers,
I had more or less given up with my modules. I thought I'd destroyed them while soldering. I decided to give them another go after a PM from another tester who wasn't getting anywhere with his modules either.
I dumped the example programs. The compiler complained at the second line of the first two programs so I didn't feel like trusting the rest. It was just a mis-spelling of an included library, but it makes me wonder if anyone at Dorji tests their examples before publishing them.
I don't have Windows, so the the usb-ttl converter and the configuration tool are useless to me.
With the modules 20cm apart the receiver doesn't miss a beat, as long as I hold the receiver's antenna between thumb and forefinger. If I let go, I get more errors than data.
I use a push-button pulled up to 3.3V and connected to GND in order to be able to reset the module independantly of the Arduino Pro Mini 3.3V, 8MHz.
I haven't tried sending AT commands, so the modules are configured as sold.
The modules are powered from 5V phone chargers connected to VDD. MO and EN are connected to GND using the jumpers on the modules.
The Arduinos are powered from each computer's USB port.
That's enough for now.
:smiley-cool:
al1fch
Hi kayel !
Quote
Maybe 20cm is to short for
Code: [Select]
High sensitivity: -143dBm @ power mode 0/1
                   -132dBm @ power mode 2
 Max. Output power: 22dBm
too strong signal  on receiver side ?
kayel
 Hi Al1fch,
 I thought my modules were probably too close to each other too, but at 1 metre apart I didn't even get errors, not even a blink from the receiver's LED, although that might have something to do with my crappy breadboards!
kayel
 These modules seem to be able to heal themselves!
 Here are my results using the lora_main example:
 I hope I haven't woken anyone up!
 :smiley-cool:
kayel
Oldtron
Finally success !
I had about given up on getting these to work. But after seeing that Kayel got his working I decided to give them another try. I connected each module to a Arduino UNO then connected one UNO to my desktop computer and one to my laptop. Then I loaded each UNO with the LORA_Main example sketch. I then opened up the serial monitor and typed in some data and pressed send. The module's Tx led came on and the other module's Rx led came on. But no data was displayed in the receiving serial monitor. No joy here. Then I decided to reset both modules to their factory settings using the LORA Modem Configuration Tool.
I fired everything back up and typed data into the desktop's serial monitor and pressed send. And after a slight delay data appeared on the laptop serial monitor about ten feet away. Next I moved my laptop about sixty feet away and tried sending again. Everything I sent came through with no errors. I can sent and receive from either module with no problems.
It appears that these modules are working as advertised. Next I will try some longer distances and check out some of their other features.
Oldtron
Just did a test at approximately 300' and had no problems. I believe these may replace my NRF24's that
seem to be really glitchy.
